Shock and lift questions.
Old 02-06-2014, 10:16 AM
SC78f150's Avatar
SC78f150
SC78f150 is offline
I have a 1978 f150 4x4 Shortbed andI'm looking to buy new shocks and steering stabilizer soon and was wondering if my truck now has only a single stabilizer can I put the dual stabilizers on it? Also I'm wanting to put 35s on my truck and believe I should put a little lift on it. I don't want nothing to high so would a 4" lift be too much with just 35's? And what all would I need? Shocks, front coil springs?? The truck has a stock suspension that I know of and has 31's on it now.
Old 02-06-2014, 11:48 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,270 Likes on 2,431 Posts
Steering stabilizers help dampen out the big bumps in a rough road and cover up bump steer, the outcome of a lift not done right. Yes you can put a duel shock kit on there.
Superlift · www.superlift.com
Looks like a 4" will let you run 35's no problem. Read here to get some lift kit info.
Suspension Systems · Superlift · www.superlift.com
Get the lift kit and new shocks, lots of places sale a complete kit with shocks.
4" Lift System · 1978 Ford 1/2-ton F-150 Pickup 4WD · Superlift · www.superlift.com
Basic lift Item #174PK-H / Skyjacker Suspensions
W/replacement rear leafs, versus just taller rear blocks Item #174PKS-N / Skyjacker Suspensions
Still need to address:
Drop pitman arm
Longer or adj trac bar versus trac bar drop bracket
Longer brake lines
Both places sale all you need and ck out Rancho and Rough Country. You need to do a F150 right lift wise with the correct pieces and parts, front end adjustment (caster&camber), front end aliment or it will drive like a POS.
Also ck out the condition of your rag joint, steering box, radius arm bushings while you are at it.
Have fun...
Old 02-06-2014, 12:13 PM
77&79F250's Avatar
77&79F250
Go here and read post #8...good stuff.
https://www.ford-trucks.com/forums/1...questions.html
Old 02-06-2014, 02:22 PM
co425's Avatar
co425
co425 is offline
Unless you run super fast off road dual steering stabilizers are a waste of money. If you have bump steer, death wobble etc, It's a better idea to rebuild your steering components and axle related steering parts. Those issues are usually a result of poor steering geometry and worn out parts.
Jon Gleason
1999 to 2016 Super Duty
01-31-2017 10:58 AM
Oscar Hernandez Jr.
09-02-2016 04:08 PM
Lil Red Sled
11-23-2011 11:27 PM
rcsjr4546
12-13-2007 01:27 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
10-02-2003 10:07 AM
Quick Reply: Shock and lift questions.
