Shock and lift questions. - Ford Truck Enthusiasts Forums
Old 02-06-2014, 11:16 AM
SC78f150's Avatar
SC78f150 SC78f150 is offline
SC78f150 is starting off with a positive reputation.
I have a 1978 f150 4x4 Shortbed andI'm looking to buy new shocks and steering stabilizer soon and was wondering if my truck now has only a single stabilizer can I put the dual stabilizers on it? Also I'm wanting to put 35s on my truck and believe I should put a little lift on it. I don't want nothing to high so would a 4" lift be too much with just 35's? And what all would I need? Shocks, front coil springs?? The truck has a stock suspension that I know of and has 31's on it now.
Old 02-06-2014, 12:48 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Steering stabilizers help dampen out the big bumps in a rough road and cover up bump steer, the outcome of a lift not done right. Yes you can put a duel shock kit on there.
Superlift www.superlift.com
Looks like a 4" will let you run 35's no problem. Read here to get some lift kit info.
Suspension Systems Superlift www.superlift.com
Get the lift kit and new shocks, lots of places sale a complete kit with shocks.
4" Lift System 1978 Ford 1/2-ton F-150 Pickup 4WD Superlift www.superlift.com
Basic lift Item #174PK-H / Skyjacker Suspensions
W/replacement rear leafs, versus just taller rear blocks Item #174PKS-N / Skyjacker Suspensions
Still need to address:
Drop pitman arm
Longer or adj trac bar versus trac bar drop bracket
Longer brake lines
Both places sale all you need and ck out Rancho and Rough Country. You need to do a F150 right lift wise with the correct pieces and parts, front end adjustment (caster&camber), front end aliment or it will drive like a POS.
Also ck out the condition of your rag joint, steering box, radius arm bushings while you are at it.
Have fun...
Old 02-06-2014, 01:13 PM
77&79F250's Avatar
Used OEM parts guy
Go here and read post #8...good stuff.
http://www.ford-trucks.com/forums/12...questions.html
Old 02-06-2014, 03:22 PM
co425's Avatar
co425 co425 is offline
co425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to allco425 is a name known to all
Unless you run super fast off road dual steering stabilizers are a waste of money. If you have bump steer, death wobble etc, It's a better idea to rebuild your steering components and axle related steering parts. Those issues are usually a result of poor steering geometry and worn out parts.
Steering Stabilizer? 1979Ford33 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-16-2015 06:14 PM
Steering Stabilizer Help shawplatinum 1999 to 2016 Super Duty 7 10-21-2014 06:19 PM
ICON Stabilizer Shock endobear 1999 - 2003 7.3L Power Stroke Diesel 0 03-16-2014 06:42 PM
Anyone have experience with Moog stabilizer shock? FordTruckEnthusaist 6.0L Power Stroke Diesel 0 01-30-2013 02:30 PM
Shocks and Stabilizers WIKD Excursion - King of SUVs 7 02-24-2012 12:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
