Timing gear question - Ford Truck Enthusiasts Forums
Old 02-06-2014, 07:06 AM
flatheadkeith's Avatar
flatheadkeith flatheadkeith is offline
flatheadkeith is starting off with a positive reputation.
Ok, When I purchased a use crank for my 239 flatty, it came with the timing gear on it. The problem I am having, is that the gear had teeth that went in the opposite direction from the old gear. I didn't notice until I tried to drop it in, that the angle of the gears were opposite, and wouldn't work. I figured I could just pull the old gear off the old crank, and press it on to the new one, but I wanted to make sure that I could. Has anyone had experience with this? Was this crank made to turn the opposite direction? Has anyone heard of a 8BA turning a different direction?
Old 02-06-2014, 08:39 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
It's from an earlier engine, like a 59ab. Used in cars through '48 and trucks through '47. Does it have the distributor drive gear? They all turn in the same direction, unless a rare marine conversion when counter-rotating engines were used in pairs....
Old 02-06-2014, 01:06 PM
It is the correct crankshaft. It is an exact match, and the part number is the same. The only difference is the gear.
Old 02-06-2014, 01:55 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Two different V8 crankshaft gears were used in 1948/49 Trucks.
48-6306-A .. Crankshaft Gear-22 left hand helical teeth-Use with camshaft gear having right hand helical teeth.
1935/47 Trucks / 1935/48 Passenger Cars / 1948/49 Trucks.
8BA-6306-A .. Crankshaft Gear-22 right hand helical teeth-Use with camshaft gear having left hand helical teeth.
1948/49 Trucks / 1949/53 Passenger Cars / 1950/53 Trucks.
Old 02-07-2014, 09:02 AM
So using the old gear on the new crank shouldn't cause problems, right?
Old 02-07-2014, 09:06 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is offline
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Quote:
That would be correct.
Two issues nards444 1999 to 2016 Super Duty 19 01-15-2016 11:23 PM
1979 F-250 4x4 Steering Problem BrandonLamb 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-24-2015 12:30 AM
SBF Crankshaft..."I didn't know that!" CharlieLed 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 04-23-2015 03:35 PM
Aligning the pump gear. akamacgyver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-10-2014 03:51 PM
302 ignition problems ColtonMullis 1973 - 1979 F-100 & Larger F-Series Trucks 29 01-05-2014 05:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
