391ft motor needed
391 4V FT: 1966/69 B/C/F/N/NT/T500/750 // 1970/78 B/C/F/L/LN500/750.
1964/78 like trucks were also available with FT: 330 2V Medium Duty - 330 2V Heavy Duty - 361 2V - 361 4V (1974/78).
All these FT engines look identical / The 4th digit of the VIN is the engine code. F = 391 4V (1966/78).
'Course, who knows if this engine is still in place today?
It's not a C600 and I assume you only want the Warranty Number (VIN) decoded.
C75 = C750 Tilt Cab.
K = 361 2V FT engine (K used 1964/65 only).
U = Louisville KY Assembly Plant.
645859 = 1965, assembled January 1965.
361 Crank is 3.5 Stroke Bore is 4..05
391 crank is 3.78 Stroke (same as 390 & 427) 391 Bore same as 390 4.052
Per my Ford Book the 330, 361 & 391 have Exhaust seat inserts.
I remember working on many at my first job which was a machine shop (nearly 40yrs ago)
330 2V H/D, 361 & 391 FT's use the same rods as 390 FE.
However, the 330 2V H/D, 361 & 391 rods are somewhat year specific. 1964/65 or 1966/70 or 1971/78.
330 2V H/D & 361 use the same crankshaft, 391 crankshaft is 391 only.
352 rod is 6.538-6.542
very low comp spec on 361-391 engines
The combustion chambers on a 361-391 average 2 cc's larger than the 352
on 361 & 391 Starting 1966
I found a motor in a one ton ford truck the air cleaner said 39* the last number was scratched so I could not make out the number.
I am thinking it is a 390 fe motor?
I am trading him some Chevy stuff for it .
I will have the block numbers tomorrow
Will a 390 fe work as will in my truck as a 391ft?
I am putting it in this!
