DUI Distributors
DUI Distributors
Anyone here have experience intalling a DUI Distributor? I just picked one up on the cheap for my 300 and was wondering if it is a pain in the butt to wire and whether I should replace the gear with a brass gear. Do I need to do anything to the oil pump shaft for it to work? Any input would be greatly appreciated!
From what I've heard, DUI is pretty close to (if not) the top of the line. All it needs is a 12v key source, so it's 1 wire. You can remove your coil and ignition module, since it's all integrated into the unit.
It also has upgraded gears, so you don't need to mess with those either.
I can't see why you'd need to do anything with the oil pump shaft.
I know a DUI setup is on my want list.
One thing you might look into with the DUI is contacting them about recurving it. DUI distributors are custom curved to your specific engine for the best performance. If you got one someone else had, it may be tuned for theirs, not yours. They should be able to recurve it for you.
For the throttle linkage, the stock bracket will no longer work at all, since it bolts to the stock intake.
I originally built my own out of some scrap metal, but recently bought myself the Lokar SRK-4000, which worked really well.
I can't speak to the DUI but I put one of their Duraspark distributors in my Bronco and it's cherry. No wiggle in the shaft and spins freely. It's not stand alone like the DUI but gives me the option of using a multi-spark CD ignition in the future. Or not, it runs sweet as candy with the DSII.
I pulled my dizzy from the j/y, a DS2, and took it to a shop with a Sun dizzy machine. They rebuilt it with a bronze gear, bearings replaced the bushing in the bottom, and they recurved it to my cam, for $175. I coupled it with an MSD box and keep a GM 4pin on the fender with wire in case the MSD fails.
