2015 F150 to be pre-fitted for snow plows? - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150
Old 02-05-2014, 07:28 PM
Frdtrkrul Frdtrkrul is offline
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
Seems as though Ford is going to add a snow plow option on all packages of the 2015 F150. They must really have a heavy duty front suspension for a snow plow. This isn't all that surprising, they've been doing it for years for the Super Duty trucks. I'm wondering since it sounds as though it's going to be standard across the board if they are offering a much stronger suspension like what was offered on the F250LD/F150 7700. Or with the reduced weight of the cab if that they won't have to.
This 2015 Ford F-150 Is Ready to Plow Some Detroit Snow
I first saw the news on my facebook feed https://www.facebook.com/photo.php?f...type=1&theater
what do you guys think?
Old 02-06-2014, 06:42 AM
tseekins's Avatar
tseekins tseekins is online now
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
You'll note that it's sporting a BOSS plow. BOSS plows are installed so the frame absorbs the majority of the shock and jarring instead of the front suspension.
This is a brilliant move for Ford and it's long overdue. http://www.bossplow.com/
Old 02-06-2014, 07:02 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I remember something about electrical power steering and snow plows not working together very well. Is that true?
Old 02-06-2014, 09:59 AM
I haven't found much information on how much the extra cost will be but I don't think it'll be more than a few hundred dollars. Seems as though they might have some sort of agreement with BOSS or if they just decided for the showing to have a BOSS plow on it.
Old 02-06-2014, 12:52 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Quote:
I believe the issues are two. One is duty cycle - that's a lot of wear on those EPAS motors going round and round in circles. Second is electrical - the alternator doesn't produce enough juice to keep up with the EPAS in such a heavy use situation, especially when engine RPM is low and there are likely other aftermarket power drains added in (lighting, etc.)
The SSV F150 has an upgraded 220A alternator and it's supposed to deliver 80% of that at idle, if memory serves. Maybe they made that alternator standard across the line?
Old 02-06-2014, 06:15 PM
If you can fit dual alternators that could work, but that's twice as many problems and twice the cost to buy new ones.
Old 02-06-2014, 08:24 PM
03 SVT VERT 03 SVT VERT is offline
03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.03 SVT VERT has a good reputation on FTE.
The plow package is only available on 4x4 trucks with the 5.0L V8 in XL, XLT, or Lariat trim. It will, however, be available on all cab/bed configurations.
Apparently what they did is incorperate a "Plow Mode" button. It shuts off some non-essential electronics while plowing to ensure the EPAS system has enough power. Not sure what exactly that means, but that's what Ford is saying.
Maximum plow weight will be just over 450lbs, so you're talking a fairly light duty plow. Still better than what they've offered for the past few years though (i.e. nothing).
Old 02-06-2014, 08:57 PM
Robbgt's Avatar
Robbgt Robbgt is offline
Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.Robbgt has a great reputation on FTE.
More plow info, seems to be just button to dedicate power to run EPAS and plow 2015 Ford F-150 Claiming To Be First Pickup With A 'Snow Plow' Button
Old 02-06-2014, 09:05 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
I keep finding more reasons why this needs to be my next truck.
Old 02-06-2014, 09:34 PM
I wonder why they are now doing this and not 10+ years ago. For needing extra power, they should've just added a larger Alternator on the trucks with this option rather than putting a switch in to shut off non-essential electronics.
Old 02-06-2014, 10:26 PM
To be fair, a larger alternator would add more drag to the engine, something they specifically don't want to do. Hence the whole purpose of going to an EPAS system in the first place, as opposed to the old engine mounted hydraulic pump.
I also doubt a a larger alternator alone would solve the problem. You would need to support that with heavier wiring, another battery, etc. All this stuff would add weight, which is the opposite of what Ford is trying to do with the new truck. If they found they could have the exact same result with a button and some programming that's undoubtedly the way they're going to go.
Old 02-06-2014, 10:47 PM
tseekins's Avatar
I figured the ecoboost engines wouldn't be a candidate to be plow trucks, most likely a cooling issue. At least Ford has moved in the right direction.
Old 02-07-2014, 03:25 AM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
other then the 11-14 non 6.2's we've been putting Boss Plows on all kinds of f-150s over the years. this green truck had a 8' super duty blade...bigger then i run on my f-250
Old 02-07-2014, 06:51 AM
svt2205 svt2205 is offline
svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.svt2205 has a good reputation on FTE.
Old 02-07-2014, 07:05 AM
redford's Avatar
I'm not exactly sure I like the idea of someone else deciding what should remain turned on and what should be turned off.
Snow plow: 3.5L Ti-VCT V6 vs 5.0L Ti-VCT V8 Turbo_Bimmer 2015+ F150 11 03-01-2016 08:00 AM
2015 announced tvsjr 2015+ F150 49 03-21-2015 10:41 AM
How to Choose the Right Snow Plow for Your Ford edtahaney 2015+ F150 0 02-20-2015 08:06 PM
That's All Folks! Ford F-150 SVT Raptor Not Available in 2015; FX2/FX4, Limited and STX Models Too edtahaney 2015+ F150 9 08-15-2014 06:01 PM
2009 F-250 SD lariat 4x4 6.4D Snow plow help JuiceLJS 1999 to 2016 Super Duty 45 11-21-2010 05:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
