New Transmission Getting Warm - Ford Truck Enthusiasts Forums
Old 02-05-2014, 03:22 PM
TKegs763 TKegs763 is offline
TKegs763 is gaining momentum as a positive member of FTE.
Hey guys I have a freshly rebuilt transmission getting warm on me and what should I check? Have it at the tranny shop right now and they said everything checked out. They put a new bypass valve in it at no charge just to be sure that wasn't it. They said the trans cooler seems to be flowing like it should and it could possibly be a weak fan clutch causing the problem? Any thoughts here folks? Water temp doesn't go up above where it normally runs and I haven't let the trans get over 220. It only gets warm when it's in drive and I am stopped at a light. When I get rolling down the road it will cool off or stay where it's at. When in park it will not climb.
Old 02-05-2014, 03:38 PM
h2guy h2guy is offline
h2guy is gaining momentum as a positive member of FTE.
You'd have to be at that light a long time before the fan clutch comes on (normally).
Also, unless you have a separate coolant gauge installed, your stock WT indicator is nothing more than an "on/off" switch. Does not give you a temp indication other than normal or too hot.
Old 02-05-2014, 04:07 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Can you hold the fan blade still while the engine is running? I wear a thick leather glove and rest my hand on the fan shroud while holding the fan still with my fingers. Don't grasp the blade, just rest a couple of fingers on the back side of the blade against the direction of rotation and then have someone start the engine. If the fan forces your fingers off the blade then it's pulling air....if you are able to keep the blade still even while the engine is running then your fan clutch is faulty.
I've seen people use a broom handle or wooden dowel but that may crack your fan so I don't really like that method.
Old 02-05-2014, 04:26 PM
Sounds scary! Haha!
Old 02-05-2014, 05:01 PM
Quote:
Originally Posted by TKegs763 View Post
Sounds scary! Haha!
Yeah, it's a bit nerve racking the first time you try something like that. It's usually best to watch someone who has experience with the procedure so you can get the idea of how to do it safely. I'll try and record a video and post it online sometime.
If you are uncomfortable with using your hand then you can try and use something like a paint roller cover or anything stiff enough to get a positive purchase on the fan blade but soft enough so it doesn't damage anything.
Old 02-05-2014, 05:04 PM
Jmatthews's Avatar
Jmatthews Jmatthews is online now
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Do you have a EOT gauge?
Old 02-05-2014, 05:10 PM
Tugly's Avatar
Tugly Tugly is online now
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Wait... I need to wrap my (bald) head around this:
"My transmission is running hot."
"Grab the fan with the engine running."
"Really?"
"Oh... I should probably mention this too: Be careful."
Pull that chip out, chips frequently alter the transmission pressures. I don't know what yours does, but getting back to Stock never hurts.
Old 02-05-2014, 05:14 PM
Quote:
"Really?"
No don't do that. Don't grab anything with the engine running. That would be crazy.
Old 02-05-2014, 05:15 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
A cold fan clutch will be locked up enough to take your hand off. Don't even think about holding a fan with an engine running.
Old 02-05-2014, 05:16 PM
Tugly: I will do that
JMatthews: I do not have an EOT Guage, but I do have AE if that helps. My oil cooler orings need to be replaced. Will that possibly have something to do with it?
It's still at the transmission shop and I will pass this info over to them. Any other things to check?
While I'm on the subject, what is the difference between "trans cooler" and "intercooler"? I want to upgrade to the 6.0, but what to get?
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Could it be the gauge or the sending unit? The temps in my experience don't climb or dissipate that quickly, climb maybe but dropping no. Especially since the TC isn't locked while driving around town at low speeds. What are you using to monitor tranny temps?
Old 02-05-2014, 05:17 PM
Trans cooler is hooked up to the Trans fluid lines and is kinda in front of the lower part of the radiator. Just follow the tranny fluid lines from the transmission. The intercooler cools the air charge after the turbo. Many folks upgrade the 7.3L Trans cooler to the bigger 6.0L trans cooler. In addition some exchange the stock intercooler with the 6.0L intercooler as well. This could be the source of the confusion.
Old 02-05-2014, 05:23 PM
Quote:
I have Autometer gauges and the guys at the shop hooked up their Snap-On scanner, which is also reading that the tranny is warm. My gauge temp is off by 20 degrees cooler from their scanner. It will catch up with their scanner when the temp stabilizes while in park. So, I guess what I'm saying is my gauge is a little slow. Lol...
So, it can be just a sensor possibly?
Old 02-05-2014, 05:25 PM
What is the temp on the shops scanner and your gauge when u say it is warm?
Old 02-05-2014, 05:32 PM
Mine says 210 and theirs says 220..
2005 F-150 5.4 Trans Leak and Slipping Questions kingnothingness 2004 - 2008 F150 6 07-09-2016 06:17 PM
Nv4500 troubleshooting help? DirtyLarry General Automotive Discussion 2 07-11-2015 07:29 PM
1995 F150 Transmission Shudders When Warm KatieJ Clutch, Transmission, Differential, Axle & Transfer Case 10 06-24-2011 07:50 PM
01 Expedition won't drive in gear cmjboyer 1997-2006 Expedition & Navigator 1 03-17-2011 03:53 PM
Transmission problem when hot towvan 1997 - 2003 F150 4 07-24-2010 08:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
