New rear fenders for 51-2 F1 are here - Ford Truck Enthusiasts Forums
Old 02-05-2014, 11:46 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Saw this ebay ad today and don't recall anyone else bringing this up. I know these fenders were on the way, but haven't seen them really available until now. Check it out. Anyone near Springfield, OH, willing to stop by their store for an in person look-see? I think we'd all like to know if they're everything they say they are.
http://www.ebay.com/itm/1951-1952-Ford-Pickup-Truck-F-1-Steel-rear-Fenders-PAIR-Hard-to-find-/161217358034?&_trksid=p2056016.l4276
Old 02-05-2014, 12:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I'd be real interested to see how they package these for shipping, and whether they arrive without dents.
Old 02-05-2014, 12:20 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I wouldn't worry about packaging, I just bought a front fender for '03 VW Passat. This thing is a little more than a formed piece of tin foil. When it was delivered to my shop via FedEx I was a little concerned because all that covered it was a rather thin wrap of cardboard. It was in perfect condition. I would think if these fenders are made just like the originals they'll be able to within stand a lot more bumping around than the VW fender. I would also hope since these fenders cost over 10X the VW fender they'd package them a lot better.
Old 02-05-2014, 12:52 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
Theyve been listed on the classic haulers site for a few weeks
Old 02-05-2014, 12:58 PM
bobj49f2's Avatar
$725 a piece doesn't seem like too bad of a price considering what a shop would charge to repair a rusty original. Plus new, rust free should be a lot better than a patched together part. I still would probably patch a set myself.
I wonder when the front fenders they are advertising will be out.
This could drop the value of used fenders.
Old 02-05-2014, 01:02 PM
Gicknordon's Avatar
The rear fender on mine was the first metal working ive ever done, and it wasnt that hard, so i dont think i would buy new rears. The fronts on the other hand, i might consider if the price isnt too high. I guess i should try and fix mine first though and see how hard theyll be compared to the rears.
Old 02-05-2014, 01:15 PM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Are they originating from Dennis Carpenter? Or somewhere else?
Old 02-05-2014, 02:07 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Guys that are having their trucks built for them by a shop should/would buy new fenders since the cost of new fenders versus labor to restore old fenders is less. However, the average do-it-yourself garage type restorer will stick with the used fenders.
I don't see the value of good used fenders dropping.
Old 02-05-2014, 02:09 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Originally Posted by Gicknordon View Post
The rear fender on mine was the first metal working I've ever done, and it wasn't that hard, so i don't think i would buy new rears. The fronts on the other hand, i might consider if the price isn't too high. I guess i should try and fix mine first though and see how hard they'll be compared to the rears.
The upper rear part, where there is a reinforcing piece running behind it, convinced me I wasn't that interested in learning metal working. If it were just the running board area, and the stay bracket area, I'd have done it.
Old 02-05-2014, 02:11 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
Same here. I did some work on the fronts with decent success for a novice. However, one did have some damage on the upper front corner. After grinding out the PO's bondo, I looked at the multi-compound curve and decided a little filler was the best alternative. My "skills" weren't quite up to that.
Overall, I am too cheap to have someone else do it and it is good to push yourself to learn something new (bodywork in this case).
Old 02-05-2014, 02:34 PM
bobj49f2's Avatar
Some times you can improve on the original design. The rear fenders on my F-2 were pretty much junk but at the time, 30+ years ago, I had to way to find any better so I patched them. I replaced the areas where the running boards bolt on, the bottom corners of the wheel openings, the rear bottom edge and the entire lip that holds the fenders to the box. I welded 14 gauge steel into the area about 3" into the fender and the lip that bolts to the box. This is a weak spot that tends to crack and rust. I haven't had any cracking or rust problems in 30+ years.
I have a set of front F-1 fenders I picked up a few weeks ago from on member of FTE that are in pretty rough shape but I just couldn't see them being scrapped. Once I start working on them I'll post pictures.
Old 02-05-2014, 04:05 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
I am currently working on my rear fenders, they were shall I say a mess. So far I have 19 hours into the passenger side, four patch panels so far and a lot of metal bumping. I have about 10-12 hours of work remaining before it is ready for color. This is my good fender. The driver side needs even more work. If these steel fenders were available for a 48 I think that I might of taken the plunge.
Old 02-05-2014, 04:23 PM
bobj49f2's Avatar
Quote:
I don't think it would take much to make these fit the '48 box with the raised panel. You'd cut out a top section and move it the appropriate amount of space. I'd be kind of nervous cutting up a $725 fender but I think it'd be a lot less work than patching a bunch of rust.
Old 02-05-2014, 06:28 PM
Gicknordon's Avatar
They had a prototype of the raised bed side fenders at the ford carlisle last summer, so they should be available soon i would think.
Old 02-05-2014, 07:01 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I will reserve judgement, but I'm willing to bet the metal is inferior to the originals.
Years ago I was restoring a '49 Chevy truck when their "new" rear fenders became available......I bought 2 and was really disappointed at how flimsy and how much thinner they were than the OE ones. They did fit ok though. Those were made in Taiwan....
1951 Marmon Herrington 1952henry 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-28-2015 01:23 AM
Lower Grille Valance 1951 1952 F1 ssg1957 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 11-16-2014 01:16 AM
Great deal on '51 -'52 complete fenders in Pa. firstrider 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-12-2014 11:34 AM
Here's an F2/F3 tailgate someone's selling - just sharing cause they are rare pineconeford 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-25-2014 11:49 PM
48-52 rust free doors not mine bigwin56f100 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 01-13-2013 12:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
