dodge rear in a F2 ???? - Ford Truck Enthusiasts Forums
Old 02-05-2014, 09:43 AM
delawarebill's Avatar
delawarebill delawarebill is offline
delawarebill is starting off with a positive reputation.
cking c/l and see a '86 3/4 ton rear "complete" from a dodge truck.
it seems a little to new to swap out for my truck... comments pls..
don't know gear ratio yet or measure measurements. just looking for opinion.
'49 F2 going into.
Old 02-05-2014, 11:26 AM
drptop70ss's Avatar
drptop70ss drptop70ss is online now
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
What is the goal with swapping out the rear?
Old 02-05-2014, 11:36 AM
mainly to get a better road tk.. 486 gears suck.. i've already found a '70 ford with 411 gears for great price but it's in the mud and not sure of the cond of brakes or if it has e-brake cables.. the dodge rear guy told me it's a 350 gear set so that's not gonna work. but he does have GM 3/4T rears.. don't know if they will fit either.. just tossing my options.. tks
Old 02-05-2014, 11:52 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Obviously, the deciding factor will be overall width and the location of the spring pads. With a flatbed and open wheels, your wheel location isn't as critical as if you're needing to stay under fenders. Take some measurements and see what you can find.
Old 02-05-2014, 02:19 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
Quote:
Just curious as to why the 3.50 gear set won't work. I always liked it as a good compromise between highway and towing.
Old 02-05-2014, 02:51 PM
drptop70ss's Avatar
I agree 3:50 to 3:73 gears would be a good fit for highway use and no overdrive assuming you are running taller tires that would normally be on a 3/4 ton truck. I use 235/85/15s on my 1 ton pickup and 4:10 gears, has overdrive and without it would be better with the 3:50 to 3:73.
Old 02-05-2014, 05:50 PM
f2 rear
Quote:
u have a syncro trans i believe, mine is not. so using a 373 to 350 ratio would be a problem going up a hill.. down shifting ??? i haven't learned that yet. i feel i'm at the upper RPM level doing 55 mph the 411's would get me 60+. not wanting to do 60 just easier on the engine at 55..
but the other question while i'm thinking of it.. i have a lead on a 8ft truck bed and i'm wondering if someone has the cross measurements of the fenders. looking for side to side of inside of fender and outside measurements..
it will be something like 4ft inside and 6 ft outside.. the '70 rear i've seen is something like 4" wider then mine.. will it fit ???????????????????
Old 02-05-2014, 06:38 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
Ford truck axles are the same width through 1972. The axles got wider with the 1973 models.
Old 02-06-2014, 01:47 AM
dmack91's Avatar
I am sure someone with more knowledge will chime in, but I believe the F2 box is 6" wider than the F1, while the fenders are narrower. I thought this combo gave the same overall width. My F1 box measures 49.5" inside at the rear of the bed, and I thought I read that the F2 was 54".
Old 02-06-2014, 06:50 AM
38 coupe's Avatar
Yes, the overall width of the F-1 and F-2 is the same. The F-2 box is wider than the F-1 box, and the F-2 fenders are narrower.
Dana 70 DRW from Dodge camper on F250? pidaster 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-11-2011 12:33 PM
Who's the biggest? Vacationtime247 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 27 06-05-2010 09:25 PM
Stock wheel Size *2fords* Brakes, Steering, Suspension, Tires, & Wheels 0 04-19-2009 02:11 PM
Dana 80 Rear 73 ford guy Offroad & 4x4 22 11-22-2008 12:05 PM
Will Dodge truck cap fit my '92 F150? timinoh 1987 - 1996 F150 & Larger F-Series Trucks 4 04-14-2002 08:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
