Brakes 1955 F-100 - Ford Truck Enthusiasts Forums
Brakes 1955 F-100
Old 02-05-2014, 09:08 AM
Kevin Alan Kevin Alan is offline
Kevin Alan is starting off with a positive reputation.
Brakes 1955 F-100
Good day. I am new to this forum so please forgive any mistakes I may make. I just recently got my dream truck, a 1955 F-100, but it does have some issues. It still has the stock brakes, drum's all the way around and what looks to be the stock master cylinder which is bad. I would, for now, like to keep the drums but upgrade the cylinder which is under the floor pan. Can anybody suggest the best way to do this. From looking on the net it seems that there are upgrades available, I'm just not sure of the best way to go. Thanks.
Old 02-05-2014, 09:33 AM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
i upgraded my '49 to a dual master, using a late 60's mustang dual master for a 4 wheel drum mustang. i got it from napa. if your system is the same as the earlier, you will need to buy or build an adapter to attach the new master to the the original mount (3 bolt to 2 bolt). you could also need an adjustable master push rod. hopefully, the folks who know about the 55's will chime in and confirm or correct what i have posted. welcome to FTE. took a quick look and here is one adapter available for your application. i'm sure you will want to look around and wait for more guidance, but the stuff is around. dick r.
http://www.performanceonline.com/195...acket-mca5356/
Old 02-05-2014, 10:58 AM
Branded Branded is online now
Branded is gaining momentum as a positive member of FTE.Branded is gaining momentum as a positive member of FTE.
Quote:
Check the for sale section, might be of some help.
http://www.ford-trucks.com/forums/12...ke-set-up.html
Master Cyl Brakes Upgrade??? Mitch1129 1948 - 1956 F1, F100 & Larger F-Series Trucks 32 12-26-2016 11:18 AM
1955 F100 Build (R) Filthy1955F100 1948 - 1956 F1, F100 & Larger F-Series Trucks 159 06-05-2016 11:25 AM
1955 F250 Brakes 55F250 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 08-05-2015 02:37 PM
Inboard Drum Brakes wintersg3 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-28-2014 10:51 AM
Anyone used Mid Fifty dual master cylinder kit #5914 for drum / drum application? carbs & chrome 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 05-17-2014 02:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
