Ashtray conversion to drink holder
I don't smoke so I've converted my to a key holder, a junk box and numerous other uses.
Seriously, I never thought about that. It sounds like a good idea and I can't see how hard it would be to insert a plate with an appropriate sized hole to hold a cup. I don't know if it'd be big enough to hold a standard cup though.
One thing to think is the ride of these old trucks, I don't know if yours has a modified suspension but with my F-2 if I had cup full of liquid in the ash tray the contents would be flying out with every bump I'd hit. Better have a lid on it.
Agreed. The tray is too small. You'd have to do a lot of modifying or design something that slides straight out like a modern cupholder.
I will say this--I found that ashtray makes a great sound amplifier for your MP3 player, smartphone, etc. I was listening to Pandora on my smartphone back in the summer. I stuck it down in that ashtray. The sound amplification was pretty good. Try it!
Agreed. The tray is too small. You'd have to do a lot of modifying or design something that slides straight out like a modern cupholder. I will say this--I found that ashtray makes a great sound amplifier for your MP3 player, smartphone, etc. I was listening to Pandora on my smartphone back in the summer. I stuck it down in that ashtray. The sound amplification was pretty good. Try it!
I installed a dual port power port in my F-2 so I could power my GPS and phone, I still have the stock positive ground 6 volt system. It worked great. Just recently I bought a USB speaker that plugs into the back of my phone charger, which has a USB port, and a jack that plugs into my phone. Now I can turn the volume up high enough to hear over truck.
One idea I'd like to offer is if you're not using the stock radio and speaker you could turn your speaker grill into a hidden cup holder. I've posted before about how a person I knew mounted the plastic speaker grill on a piece of sheet metal that followed the contour of the dash. He then hinged the bottom and use a spring loaded key chain to pull it back into position to hide a modern sound system control unit. You could do the same thing but install a couple of short pieces of PVC pipe that would fit the bottom of the cups. When not in use it would fold back up to the dash.
