Ashtray conversion to drink holder - Ford Truck Enthusiasts Forums
Old 02-05-2014, 08:50 AM
Tyler S's Avatar
Tyler S Tyler S is offline
Tyler S has a good reputation on FTE.Tyler S has a good reputation on FTE.Tyler S has a good reputation on FTE.
Has anyone converted their F1 ashtray to a cup holder? Wondering if its possible and practical...t
Old 02-05-2014, 10:04 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I don't smoke so I've converted my to a key holder, a junk box and numerous other uses.
Seriously, I never thought about that. It sounds like a good idea and I can't see how hard it would be to insert a plate with an appropriate sized hole to hold a cup. I don't know if it'd be big enough to hold a standard cup though.
One thing to think is the ride of these old trucks, I don't know if yours has a modified suspension but with my F-2 if I had cup full of liquid in the ash tray the contents would be flying out with every bump I'd hit. Better have a lid on it.
Old 02-05-2014, 10:09 AM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Agreed. The tray is too small. You'd have to do a lot of modifying or design something that slides straight out like a modern cupholder.
I will say this--I found that ashtray makes a great sound amplifier for your MP3 player, smartphone, etc. I was listening to Pandora on my smartphone back in the summer. I stuck it down in that ashtray. The sound amplification was pretty good. Try it!
Old 02-05-2014, 10:15 AM
Tyler S's Avatar
Quote:
Originally Posted by Doc View Post
Agreed. The tray is too small. You'd have to do a lot of modifying or design something that slides straight out like a modern cupholder. I will say this--I found that ashtray makes a great sound amplifier for your MP3 player, smartphone, etc. I was listening to Pandora on my smartphone back in the summer. I stuck it down in that ashtray. The sound amplification was pretty good. Try it!
Hey, that'd be lot cheaper than a $1000 stereo system!!
Old 02-05-2014, 10:27 AM
bobj49f2's Avatar
I installed a dual port power port in my F-2 so I could power my GPS and phone, I still have the stock positive ground 6 volt system. It worked great. Just recently I bought a USB speaker that plugs into the back of my phone charger, which has a USB port, and a jack that plugs into my phone. Now I can turn the volume up high enough to hear over truck.
Old 02-05-2014, 11:33 AM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
You may want to reach out to Ben73058 - as I recall, he installed some swinging cup holders in a '50...
Old 02-05-2014, 12:08 PM
GLR's Avatar
GLR GLR is online now
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
If you put a couple of old boots on the floor, they make good cup holders.
Old 02-05-2014, 01:41 PM
49f3dls's Avatar
49f3dls 49f3dls is online now
49f3dls is a name known to all49f3dls is a name known to all49f3dls is a name known to all49f3dls is a name known to all49f3dls is a name known to all49f3dls is a name known to all
Quote:
And they look period correct also
Old 02-05-2014, 02:37 PM
bobj49f2's Avatar
One idea I'd like to offer is if you're not using the stock radio and speaker you could turn your speaker grill into a hidden cup holder. I've posted before about how a person I knew mounted the plastic speaker grill on a piece of sheet metal that followed the contour of the dash. He then hinged the bottom and use a spring loaded key chain to pull it back into position to hide a modern sound system control unit. You could do the same thing but install a couple of short pieces of PVC pipe that would fit the bottom of the cups. When not in use it would fold back up to the dash.
Old 02-05-2014, 05:59 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
My heat and ac controls are mounted where the ashtray used to be. I'm using boat cup holders that I've installed on the forward, upper portion of the doors, below the vent windows. They're the fold out type, available in any boat or camping store.
Old 02-05-2014, 06:59 PM
homade's Avatar
homade homade is offline
homade has a very good reputation on FTE.homade has a very good reputation on FTE.homade has a very good reputation on FTE.
I'm using tractor supply fold out tractor cup holders, about 3 1/2 in square, mount on door below cozy wing,about 3/4 in thick pulled down and spring fingers open up. Ofcourse they are black and with a small blue oval self adheasive logo they look right at home.
Old 02-05-2014, 07:42 PM
Tyler S's Avatar
Quote:
Hey Hopper can you post a pic of those on this thread? Thx in advance. T
Old 02-05-2014, 07:44 PM
Tyler S's Avatar
Quote:
Homade, my man, can you post a pic of your cup holders? Thx! T
Old 02-05-2014, 08:20 PM
bra$$monkey's Avatar
bra$$monkey bra$$monkey is offline
bra$$monkey is starting off with a positive reputation.
I use mine as a phone holder - holds it perfectly so I can use the GPS
Old 02-05-2014, 08:52 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Quote:
Same here. I also use an app on my phone for a speedometer, since my speedo is so far off calibration.
Ash tray cup holder? ymountainman 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-08-2016 07:58 AM
LMC cup holder F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-10-2016 10:47 AM
ash tray light xcrider76 New Member Introductions 1 09-14-2015 12:44 PM
Looking for cup holder/ashtray BLADE35 6.0L Power Stroke Diesel 2 02-15-2015 10:19 PM
LMC Ashtray Drink Holder 82GT 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-17-2010 02:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
