Uh-Oh! I Just Bought A Cummins... - Ford Truck Enthusiasts Forums
Old 02-04-2014, 09:18 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Today I finally pulled the trigger on a Cummins. It has the rotary VE pump. It should be here by next Wednesday.
The plan is to run Destroked's adapter and flex plate to mate the Cummins to my E4OD. It's going in 'Ol White.
Old 02-07-2014, 08:15 AM
kanuck15's Avatar
kanuck15 kanuck15 is offline
kanuck15 is starting off with a positive reputation.
whats wrong with the IDI thats in it?
Old 02-07-2014, 06:11 PM
Quote:
It's thirsty for oil, has a sticky or burnt valve, needs injectors and is severely underpowered.
Want to buy a cheap IDI?
Old 02-08-2014, 07:07 AM
kanuck15's Avatar
Fair enough reason. Lol I am good without an Idi, Id have to retrofit my truck to use it anyways
Old 02-28-2014, 11:13 PM
Truck Guy99's Avatar
Truck Guy99 Truck Guy99 is offline
Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.Truck Guy99 has a good reputation on FTE.
Did you ever get started on this? I'm interested in this thread and it looks like it has potential
Old 03-02-2014, 04:40 PM
I finally got the motor Wednesday (two weeks late). The adapter plate, flexplate, radiator, and motor mounts are here. A new cam, intercooler, lift pump, govenor spring, and tachometer kit are all on the way.
I will try to get some pictures.
Old 03-02-2014, 06:24 PM
Them 4 cylinders are short, ain't they?
Old 03-10-2014, 06:18 PM
The plan is to cut a cylinder off each end and run it up side down.
Old 03-10-2014, 07:28 PM
Finally! No more leaky, smoking, missing, ticking IDI.
There's a lot more room with that boat anchor out of there.
Old 03-12-2014, 08:58 AM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Nice change to the typical cummins swaps that everyone and there brother have been doing. I like seeing the 4 Cyl builds and also the more exotic non cummins diesel swaps. What are the specs on that cam? And do you mind saying what you paid for the adapter plate and flex plate everything needed to run the E4OD
Old 03-12-2014, 07:05 PM
The main reason I am doing the 4BTA is that most everyone I talk to tells me that it won't have enough power to use the truck like a one ton. That, and who in there right mind would put a 4 cylinder in one ton? I figure that I should be able to get 250 - 300 horsepower out of it which should give me upwards of 550 ft lbs of torque - maybe more.
The adapter plate, flexplate, and starter was just shy of $1400. As for running the E4OD, I'm going to do like everyone says I can't and just send the ECM a tach signal of 53 pulses per revolution and be done.
Oh yes, I am taking my throttle pedal and morphing it with a 6.0 pedal to get a TPS.
Old 03-13-2014, 08:53 PM
I love that 4BT powered brown truck that stops by every once and a while.
The manifold cut down nicely. I am a pretty good welder but I've never brazed too much before.
Not to bad for starters, eh?
Old 03-14-2014, 08:31 PM
grinnergetter's Avatar
grinnergetter grinnergetter is offline
grinnergetter has a good reputation on FTE.grinnergetter has a good reputation on FTE.
Looks like a pretty nice start to me. Looking forward to watching the adventure.
Old 03-14-2014, 08:38 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
What turbo are you going with?
Sent from my mind thanks to the Internet and an app.
Old 03-15-2014, 07:26 PM
Quote:
I'm thinking a HE351CW, or maybe a 341. I have also been tossing around the idea of twins. I need to pull the trigger on a setup pretty soon.
What do you all think?
Intercooler bushings Renegade3064 1999 to 2016 Super Duty 2 03-23-2016 07:52 AM
High Mount Cummins A/C Bracket fordtrucknut 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-14-2016 05:55 PM
Thinking of Doing a Cummins Conversion Copterdctr 1987 - 1996 F150 & Larger F-Series Trucks 34 12-27-2015 05:33 PM
How to swap to Cummins fordpower1993 Engine Swaps 6 05-09-2015 07:03 PM
Cummins Swap into 79 Ford RedStroke Engine Swaps 5 03-16-2006 04:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
