1973 Ford F-600 Gas-Perkins Conversion - Ford Truck Enthusiasts Forums
Old 02-04-2014, 08:22 PM
LRShooting LRShooting is offline
LRShooting is starting off with a positive reputation.
We have a 1973 F-600 that will need a engine pretty soon. We use it as a tender truck for hauling soybean seed around to the planter. The engine goes through oil faster than anything I've ever seen. Its been run to almost dry a couple times. We have a Perkins 354 diesel out of a old MF 550 thats been setting around for probably 10 years. After a diesel flush, it fired right up. I was wondering if any of you have experience in doing a Perkins swap. I know it has been done with quite a few 70's era Ford trucks with the majority of them being light duty. Engine mounts seem to be pretty straight forward and I am not to worried about that. However, I am worried about bell housing fitment and speed issues. Perkins comes with a SAE bell housing, but I don't know about ford. I can build a bell housing and it has been done with stuff like car rims and steel place even. A bell housing that would fit into place would be preferred though. Also, how can I up the speed? I'm pretty sure that MF 550 only ran around 2200 rpm like most farm equipment. Only thing I can think of it a differential ratio change or a gear box that would bolt to the tranny and change the speed.
Now I realize it would be simpler to just find another gas engine or rebuild this one which is probably fried, but Id really like to have that perkins in it. The extra torque would help a lot going up some of the hills we have around here. Not only that, but it gets used as a overflow in good corn since we don't have a grain cart ATM. It'd really suck to have the gas engine die on me going up hill with a full load and a .5 mile long steep hill to go backwards down. Call me a idiot, but this truck only has one working brake in the front, and it barely works at that...LOL.
Old 02-04-2014, 10:38 PM
VocaTexas VocaTexas is offline
VocaTexas is gaining momentum as a positive member of FTE.VocaTexas is gaining momentum as a positive member of FTE.
Send off for their info. It's right up your alley:
Shade Tree Conversions at Shade Tree Conversions.
Old 02-04-2014, 10:48 PM
Actually, I have their book... If the F-600 is the same, rock on! Otherwise, it mainly just covers small trucks.
Old 02-04-2014, 11:03 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
From what I have read, the ag engines can break the crank snout in auto applications because they aren't properly dampened. The continuously varying rpms apparently take their toll.
Other than that, I am really interested in a Perkins swap!
Old 02-05-2014, 12:16 AM
teds74ford... This applies to basically combines only. Some other equipment is the same way, but generally combines. Reason being that once your going in a combine, you stay top rpm and don't speed up/slow down. Being properly dampened actually ends up meaning just swapping the damper because the original doesn't have any dampening material. Its just a pulley. If I can and if I actually do it, Ill try to post a few pictures. Big issue with a damper on this is that I can't find one, and its hard to tell if dampening a motor that was not built to have a damper will work.
BTW, I use damper and harmonic balancer the same even if their not in case your confused.
Old 02-07-2014, 09:35 AM
teds74ford's Avatar
Interesting. I thought most of them had this problem, but you are saying that tractors and other stuff have the damper/harmonic balancer?
Old 02-07-2014, 11:48 AM
Exactly. For example, a Massey Ferguson 1100 has a damper and it also has the Perkins 354 in it. Problem is that Perkins has 152 different cranks in the 354 engines.I need to take some measurements and call around. I already have called a dealer and a damper will run 1700$ new. I could buy a decent 6BT cummins for that and itd probably mate up better. I might be able to find a used damper for way cheap though or trade engines for a perkins that already has a damper.
Old 02-07-2014, 08:42 PM
teds74ford's Avatar
I am toying with looking for either a 6 or a 4 cyl diesel for my crew. Do the 4 bangers come with the correct damper?
Old 02-08-2014, 10:05 AM
Honestly, cylinder numbers don't matter. Whats going to matter is what the motor came out of. IMO, you should get a cummins. The parts are WAY easier to find. Perkins is not all that popular. And Im sure parts are cheaper. I mean, 1700$ for a damper? Thats ridiculous. The dampers on our big John Deere 4wds don't even cost that much. And the engines are twice the size. Im still looking for a damper, but there's no guarantee itll fit.
Old 02-10-2014, 01:50 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
I can't remember his name off the top of my head right now, but there is a guy on here with a 75 250 or 350 that has a 6.0 perkins in it, he knows a fair bit about the 354 as well.
You could try bridgeport tractor works about a damper. Their yard is huge and they are pretty knowledgeable, although they are not always the cheapest.
The 354 used either a #2 or a #3 SAE bellhousing, so a bellhousing shouldn't be too bad, just pay attention to input shaft length. I believe that the 477 and 534 had SAE bells, you could also try a tranny from behind a 3208(not sure which bell they use, I'm guessing a #3)
My brother in laws cousin was going to scrap a couple 550 combines cause the tires were too expensive. I'm currently dealing with him to get the two 6.354's so I'm in the same boat as you. I want one in the 57 F350 and one in the 55 F600.
Old 02-10-2014, 01:56 AM
Also cat owns perkins now which is probably why the dealer wanted so much for the damper. Cats are incredible engines, but they paint them yellow. To remind you of the gold they charge for them!
Old 02-10-2014, 04:05 PM
perky's Avatar
perky perky is offline
perky is starting off with a positive reputation.
Definitely needs a balancer.I broke 2 372 cranks yes there is alot of them difference in how they have been harden and if the front of the crank is splined
are keyed.I did a balancer for a guy 10 yrs ago buy turning the pully down to make a hub and then used a small block Chevy balancer turned the center out from the back side to fit the piece from the Perkins he used the Chevrolet pulleys worked out great he put 70.000 mile on the suburban before somebody smashed into the side of him.he had a Chevy adaptor.
The 372 Perkins I had came from a 750MF combine turbo had it turned up and running 2700rpm.there are at least 2 different saw 3 motor housings different depths I have both had them for Allison.there great motors and have more lower end grunt than the Cummins.I run both the Cummins and Perkins.yes the Cummins will run faster stop light to stoplight.But pulling a load up a hill Perkins will out do the Cummins stock for stock.And is fuel efficient.
sorry for such a long post.
And yes after Cat bout Perkins prices triple. I have been buying parts from AgKits.com
great people to deal with.
My buddy has a 65 Chevrolet with a 354 in it running a Chevy adaptor.
Dale
Old 12-05-2014, 01:00 PM
kehoeautomotive kehoeautomotive is offline
kehoeautomotive is starting off with a positive reputation.
I have a Perkins engine fully dressed that was just pulled out of a 76 f150 big block. I have the mating plate, all of the accessories to bolt it in etc. free. You can have it. It's a Perkins 4.236 out of a Massey combine. Engine runs but has a rod knock. Injection pump recently rebuilt. New clutch and flywheel too. It was bolted to manual transmission.
Motor Swap In 1983: A Story kehoeautomotive 1973 - 1979 F-100 & Larger F-Series Trucks 17 11-13-2015 03:24 AM
83 Perkins - locating parts CarolinaRanger Ranger & B-Series 7 12-17-2014 09:56 AM
Turboing a 354 perkins. LRShooting Large Truck 5 02-24-2014 12:40 AM
75 F250 SC with Perkins Phaser perky 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-03-2012 02:06 PM
How do i mate a PERKINS TO A CLARK 5speed? FarmerBill Clutch, Transmission, Differential, Axle & Transfer Case 3 12-11-2011 04:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
