Vibration on low gears - Ford Truck Enthusiasts Forums
Old 02-04-2014, 07:48 PM
mtorres555 mtorres555 is offline
mtorres555 is starting off with a positive reputation.
I have a 2000 Ford F-150 with approx. 214,000 miles on it. Recently, I've noticed that it vibrates at very low idling and start-up speeds. Can someone please give me some (hopefully less expensive) issues to look into?
Old 02-07-2014, 02:54 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Welcome to the forum.
I would start with the easy stuff like how old are the plugs? MAF clean?
Old 02-07-2014, 04:30 PM
Thanks for your response LxMan1! I recently had a tune up done a few months ago, so the plugs should be good. In reviewing my paperwork from the shop at the time of the tune-up, they noted that there was a mis-fire on #2 at that point. I wonder if there is something wrong with the housing assembly.
Old 02-21-2014, 07:09 PM
orbust orbust is offline
orbust is starting off with a positive reputation.
I would start by checking the plugs and coils. When a coil or two goes bad it can cause a serious vibration that is typically felt at low loads such as cruising at freeway speeds. I have seen a truck with two bad coils feel like it was going to rattle itself apart at cruising speeds. I have heard people incorrectly diagnose this as water in the fuel tank. After that I would probably move toward the rear diff and the tranny and drivetrain components such as u joints.
Old 02-21-2014, 07:49 PM
Orbust, thank you for responding to my inquiry! Although I've taken my truck in for a reading of the codes on the CHECK ENGINE LIGHT, they never mentioned anything about the coils. I'm gonna take it in and ask the shop to specifically look at the coils.
Old 02-21-2014, 09:37 PM
NP, Also... might want to have them check torque converter as well. Another possibility when it comes to low load vibration.
low speed vibration rear end mwebso5 1999 to 2016 Super Duty 6 09-16-2015 08:34 PM
Vibration Diagnosis... Splash67 Excursion - King of SUVs 22 02-10-2015 12:00 PM
flathead 8 running on 4? dangson 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-06-2014 11:37 PM
7.3 engine vibration wocooke77 1999 - 2003 7.3L Power Stroke Diesel 8 11-25-2013 03:33 PM
Need Help with a vibration.... drtyhatch 1999 to 2016 Super Duty 7 05-26-2012 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
