Gear ratio question - Ford Truck Enthusiasts Forums
Gear ratio question
Old 02-04-2014, 06:53 PM
my 66 my 66 is offline
my 66 is starting off with a positive reputation.
Gear ratio question
I have a 65 f-100 with a 302 with a mild cam. The truck has a 5 spd out of a 95 f-150 I-6. I have the rearend out of the truck the trans came out of and i want to put it in the truck. The tag on the rearend has S842A
73 88 1A09
Can someone tell me the ratio of this rearend?
Also has anyone had this setup are close to it and how did it work? I will pull a car trailer now and then and i would like to know if it will do the job?
Thanks for any help you can give.
Old 02-04-2014, 07:35 PM
norfolknova norfolknova is offline
norfolknova is gaining momentum as a positive member of FTE.
It looks like you are missing a digit, but from what you posted it looks like a 3.73 gear with an 8.8 inch ring gear made in 1991?? january 9th
I found this using google
Differential Identification | West Coast Differentials
You should do o.k. towing with that combo
matt
Old 02-04-2014, 08:00 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
OBS trucks never came with 3.73 gears from the factory. I think we need more tag numbers.
Old 02-04-2014, 09:03 PM
Thanks
Thanks for the replys i will recheck the tag tomorrow and she if i can see the missing number and let ya'll know. Thanks Don
Old 02-04-2014, 11:03 PM
M_Jennings's Avatar
M_Jennings M_Jennings is offline
M_Jennings is starting off with a positive reputation.
most likely 2.73
Old 02-05-2014, 09:05 AM
rla2005's Avatar
Quote:
Originally Posted by M_Jennings View Post
most likely 2.73
X2
Old 02-05-2014, 09:48 AM
checked the tag this morning and their is a 2 next to the bolt which makes it a 2.73 ratio. So with my 302 how will it be suited for pulling a car trailer now and then. I looked on the west coast site and it stated small block should turn 1800, to 2800 rpms at highway speed. so is highway speed 55, 60,65or70 mph. The site said 2.73 with 235-75-r15 at 70mph it will turn about 1779 rpms. What do ya'll think?
Old 02-05-2014, 09:51 AM
rla2005's Avatar
No way would I ever consider a 2.73 gear ratio in any truck. 3.55 or better is my recommendation. Why Ford ever put such a tall gear in a truck is beyond me.
Old 02-05-2014, 10:42 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
This should say it all, the factory tow rating for an I6 truck with manual trans and 2.73 gears was ZERO. Go find yourself a 3.55LS axle.. it was very common in 5.0 and 5.8 1/2 ton trucks.
Old 02-05-2014, 11:26 AM
skyfox10's Avatar
skyfox10 skyfox10 is offline
skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.skyfox10 has a very good reputation on FTE.
Quote:
I think it was actually zero to 2100 lbs
The 3.55 with bring that up to 3600.
Old 02-05-2014, 05:05 PM
Ok we not putting the 2.73 rear in the truck. Now, the tag on the stock rear reads BG-f2 3.89 3MG 301. I think this tells me its a 3.89 ratio rear which should pull my trailer fine. So if i rebuild my stock 9" rear with the 3.89 i would like to get another chunk and put some taller gears for when i'am around home in south louisiana (flat) and not pulling are carrying a load. Would 2.73 be ok with my 302 mild cam 5 spd?
Old 02-05-2014, 06:45 PM
rla2005's Avatar
Quote:
See my answer in Post# 8: Ford Truck Enthusiasts Forums - View Single Post - Gear ratio question
That 302 needs RPM to build some torque. Add in a "mild cam" now your power curve is shifted to the right versus a stock 302. That means it may makes less torque for the same RPM in the lower RPM range. Stick to the 3.89 geared 9" and call it day.
rearend swap dumptruck denny Clutch, Transmission, Differential, Axle & Transfer Case 1 02-20-2016 08:48 PM
Dana 60 Rearend swap gtotiger65 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-05-2015 10:33 AM
65 ford f100 rearend ? diesel jim 1961 - 1966 F-100 & Larger F-Series Trucks 1 09-17-2013 09:40 AM
1952 F-1 Ford Pickup rearend Fordpk52 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 09-26-2012 01:40 AM
Tell me about my Dana 70 Rearend brobrad 1967 - 1972 F-100 & Larger F-Series Trucks 15 05-08-2012 02:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
