Clutch Replacement - Ford Truck Enthusiasts Forums
Clutch Replacement
Old 02-04-2014, 05:56 PM
fabieber fabieber is offline
fabieber is gaining momentum as a positive member of FTE.fabieber is gaining momentum as a positive member of FTE.
Clutch Replacement
Removed Floyd's clutch assembly. The disc is really messed up on the pressure plate side. Do you guys think I need to replace the pressure plate as well as the disc?
I also read somewhere that I should have the flywheel checked to make sure it isn't warped. If so, how so I do that?
Before I took it apart I can tell you the truck jumped like crazy as I engaged the clutch.
Fred
Old 02-04-2014, 06:01 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
IMO, a correct clutch job would include a resurface of the flywheel, new or rebuilt pressure plate, disk, throwout bearing and pilot bearing. Many professional mechanics will not do the job unless they do all this. You may get by with less.
Old 02-04-2014, 06:20 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Its one of those things where, "since you've got it torn apart you might as well go all the way"
It would be a shame to just slap another clutch disc in there and still have a nasty clutch chatter. I say, go ahead and pull the flywheel and drop it off at a machine shop to get resurfaced, buy a complete clutch kit and replace the disc, pressure plate, pilot bushing, and throw-out bearing. (pretty amazing advice coming from me since I'm the ultimate cheapskate....LOL)
Do it all, do it once
Bobby
Old 02-04-2014, 06:29 PM
Steve's Avatar
Steve Steve is offline
Steve is gaining momentum as a positive member of FTE.Steve is gaining momentum as a positive member of FTE.
All good advice. Another pearl of wisdom is to be sure and clean all the oil off the cover and the flywheel (and your hands) really well before bolting it all together. These trucks are already prone to clutch chatter under the best of circumstances, and you'll want every advantage. I finally went with a diaphragm style cover and solved all my chatter woes....
Old 02-04-2014, 07:55 PM
Thank you guys. I do want to do this right so will follow your advice.
Now, where is the best place to buy the parts?
Old 02-04-2014, 08:10 PM
larryb346 larryb346 is offline
larryb346 has a good reputation on FTE.larryb346 has a good reputation on FTE.
I would replace it all.
However I would try to have someone rebuild the parts you have.
With every thing being done over seas the quality of parts is poor at best.
You should be able to locate a shop that would be able to rebuild your pressure plate and reface your disk at about the same price or cheaper than getting some Chinese part. I would also reface the flywheel. I don't like pulling the trans. more that once so when I put it back together I want it to be finished,and not have to do it again due to some cheap part failure.
Old 02-04-2014, 08:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
It sounds like your rear seal is getting oil all over the clutch. Unless you fix that, you'll have a repeat performance.
Edit: I guess I'm not clear what you mean by "messed up"
Old 02-04-2014, 08:21 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
I agree with Ross check for an oil leak too! Oil on a clutch will cause chatter and will kill your new clutch quickly.
Back in the day you could get a clutch repair kit that had everything except the flywheel resurfaced. Get the flywheel checked for cracks and resurfaced at your local machine shop.
Old 02-04-2014, 09:54 PM
Ross and BJ - I didn't find evidence of oil on the clutch components but there seemed to be three streaks of "grease" on the outside (backside) of the pressure plate. I am unable to tell where the substance originated.
Would a parts store, like NAPA, be a starting point for rebuilding the plate and disc?
Old 02-04-2014, 10:01 PM
They sell rebuilt pressure plates. If they have a machine shop they should be able to help or at least recommend some one.
Old 02-04-2014, 10:10 PM
Thank you sirs!
Old 02-04-2014, 10:19 PM
No sirs just fellow FTErs
Old 02-05-2014, 12:56 AM
Thank you FTEs!
Ross, missed your query about "messed Up' referring to the disc. The pressure plate side of the disc was unevenly worn on the asbestos or whatever that stuff is made of. The grooves between the "pads" were nearly filled with what I assume is the scuffed off pad material.
Old 02-05-2014, 10:37 AM
ALBUQ F-1's Avatar
postin' fool
AFAIK, NAPA no longer carries any of the clutch components for an F-1. A shame because I got two quality rebuilt clutches there.
Old 02-05-2014, 03:38 PM
fabieber,
Just got a new SpeedwayMotors catalog #373. I think they have the stuff you need check out page 278.
Locked up clutch Moe power stroker 1999 to 2016 Super Duty 3 09-14-2015 07:07 AM
IDI clutch Kj.keiscome Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-12-2015 11:23 PM
4.9 vs 5.8 pressure plate differences? Motorhead351 Clutch, Transmission, Differential, Axle & Transfer Case 1 05-02-2014 11:21 PM
Where to buy clutch kit? fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 03-09-2014 11:28 PM
Adjusting a hydraulic clutch?? Thoth88 Ranger & B-Series 3 01-14-2014 11:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
