Clutch Replacement - Page 2 - Ford Truck Enthusiasts Forums
Clutch Replacement
Old 02-05-2014, 04:39 PM
fabieber fabieber is offline
fabieber is gaining momentum as a positive member of FTE.fabieber is gaining momentum as a positive member of FTE.
Thank you BJ.
Old 02-05-2014, 07:34 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Quote:
Originally Posted by fabieber View Post
Thank you BJ.
No problem. Keep us up on what you end up doing.
Old 02-07-2014, 03:38 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Look in the phone book (or internet) for brake rebuilders, most also do clutches. I know of a great place in San Jose, CA if you don't find a local place. Check with the semi truck repair shops, they should know a local rebuilder.
Old 02-07-2014, 03:44 PM
Steve's Avatar
Steve Steve is offline
Steve is gaining momentum as a positive member of FTE.Steve is gaining momentum as a positive member of FTE.
Dave-
Performance Friction in SJ?
Old 02-07-2014, 04:28 PM
I think that it could be them, I heard they changed names since I used them as mechanic for a glass company in the 80's, it used to be Superior Clutch and Brake near Brockow and 101.
Old 02-07-2014, 04:36 PM
Steve's Avatar
Right- now I remember- Superior Friction. Robin is his name, and he is an encyclopedia when it comes to clutches. He built the 11-inch diaphragm style cover, dual surface disk for the Y block in my '56, and he built a very strong kevlar faced unit for my' '90 F250. Excellent idea......
Locked up clutch Moe power stroker 1999 to 2016 Super Duty 3 09-14-2015 07:07 AM
IDI clutch Kj.keiscome Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 09-12-2015 11:23 PM
4.9 vs 5.8 pressure plate differences? Motorhead351 Clutch, Transmission, Differential, Axle & Transfer Case 1 05-02-2014 11:21 PM
Where to buy clutch kit? fabieber 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 03-09-2014 11:28 PM
Adjusting a hydraulic clutch?? Thoth88 Ranger & B-Series 3 01-14-2014 11:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
