General Diesel Discussion
6.0 to 12v Cummins swap
  #121
Old 04-07-2014, 11:17 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
Since you weren't specific on a "Diesel working" video, here's one I took at a local diesel "gathering" of a guy flogging his Duramax because someone gave him an old set of tires to use up... he did this at least 6 times that night and somehow the truck is still going even-though his turbo and down-pipe got hot enough it started melting the plastic push pins holding the insulation to the firewall...
VIDEO0029_zpsae8f65fd.mp4 Video by kert0307 | Photobucket
  #122
Old 04-07-2014, 09:41 PM
Mr.Nobody's Avatar
Mr.Nobody
Mr.Nobody is offline
SMOKE SHOW!
  #123
Old 07-29-2014, 09:55 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
Just an update. I've got about 8k on this thing since the swap. The two 16" electric fans are doing great at keeping it cool even when pulling a trailer in stop and go traffic in the 90's. Daily mpg's is similar to the 6.0, but towing mileage is a lot better. Still haven't hooked up the AC or cruise yet either.
  #124
Old 08-22-2014, 01:47 PM
Jeff Watts's Avatar
Jeff Watts
Jeff Watts is offline
Bump/Tag/Subscribe.
I'm interested in the cruise, fans and A/C. My 6.0 just melted down, so I'm looking at a 12 valve ZF-5 swap.
I'd really like to be able to use the factory 6.0 fan.
  #125
Old 11-18-2014, 02:28 PM
Don Rush's Avatar
Don Rush
Don Rush is offline
Fummins
I too have been lurking on this thread for months.
. I am down to just the cruise control needing to be hooked up. Thanks for the detailed posts!
  #126
Old 11-21-2014, 08:50 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
Not really related to the swap, just changed up the front of the truck after doing some deer hunting with it...
Painted the new bumper to match the lower two tone of the truck and replaced the fog lights with a single 20" LED light.
  #127
Old 11-23-2014, 11:08 PM
Mr.Nobody's Avatar
Mr.Nobody
Looks real nice.
  #128
Old 12-06-2014, 10:43 PM
Crashcraddock's Avatar
Crashcraddock
Crashcraddock is offline
Looking good, like the led bar i stead of the fogs. I currently have a dead 6.0 Excursion that I've been thinking about putting a cummins in. Truck has been sitting for 2 years, I even purchased an 04 2500 dodge runner to use as a donor but had to sell it due to personal problems. Anyways, a question I have is who did you use to tune the trans? Sounds like it but did you get it shifting right with the 6.0 converter? Would you go the tune your 5r's tcm route again or something else?
Thanks in advance for any info.
  #129
Old 12-08-2014, 08:37 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
If I did it again, I would still go with tuning the Ford PCM. That way I still get the tow/haul function.
The things I would change
1. Go with a lower stall torque converter
2. Keep the 6.0 crank sensor (and use a custom mount) and use it with the swap kit's tone ring, the tach sensor provided is garbage.
  #130
Old 12-08-2014, 07:56 PM
Crashcraddock
Thanks, just the advice I need. I'll be starting this project next month with an 04 motor.
  #131
Old 12-21-2014, 08:31 PM
jordantmashos's Avatar
jordantmashos
jordantmashos is offline
What kit did you use? Options? Etc. I'm looking at pulling a 6.0 from a 2004 f350 and want to put a 12 valve into it. Any advice and ideas would be greatly appreciated.I'd be using it to haul horse trailers and wood regularly, as well as driving on the interstate and towing other vehicles. Working on a farm down dirt roads, going hunting in the mountains.
  #132
Old 12-21-2014, 09:41 PM
Jeff Watts's Avatar
Jeff Watts
I feel bad for saying this, but I chickened out. I'm looking for a buildable long block to fix the truck. I'm still going to build a Fummins, but I'm going to use a 79 king cab.
  #133
Old 12-22-2014, 10:01 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
The kit I used was from Diesel Conversion Specialists.
If you're on a budget, I would keep the Dodge trans, preferably a manual. You're going to pay more than 2k to keep the 5r110 trans.
If you want an auto and have the cash, the 5r110 is hard to beat though.
In all honesty, the swap is pretty easy if you buy the kits. Just follow the instructions and do some wrenching. With the engine mounts and adapter plates everything pretty much bolts in.
  #134
Old 12-25-2014, 09:07 PM
Portuga's Avatar
Portuga
Portuga is offline
Great thread, lots of good info.
Just picked up a 2000 v10 excursion with what looks like a locked up engine. Gonna stick a 6bt in it over the course of next year, definitely gonna be coming back to this thread for info!
  #135
Old 12-30-2014, 11:50 AM
jordantmashos
Does Diesel Conversion Specialists have a kit to keep the original dodge nv4500?
Quick Reply: 6.0 to 12v Cummins swap
