power steering question
I'm pretty sure there are no O rings. If you're sure you have the fittings tight, I would remove the fittings an check for residue or part of a plug remaining underneath where they are supposed to seal. Also check the surface where they are supposed to seal for any burrs or pits. You may have gotten a bad reman box.
nope no tape on the threads,
Sorry about the delay in posting I had another issue with the truck that has kinda put the steering box on hold, blew a freeze plug in southern CA weather (wtf). truck will be back on the road when the steering issue is fixed but it wont be long until the motor gets rebuilt.
I went and got some degreaser and am gunna clean the area tonight and look for leaks in the system and hopefully find them.
Ill post back with results
Alex from GA
11-02-2005 08:08 PM
weverette1
02-02-2005 02:57 PM
