What brand oil filter do you use? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 02-03-2014, 05:52 PM
King Rex's Avatar
King Rex King Rex is offline
King Rex is gaining momentum as a positive member of FTE.
I am curious, I can read the differences between filters, but if you change your oil (and filter) every 3k or so, does it really matter? I have used frame in every car I have owned... That being said, I rarely keep my vehicles that long so maybe I have not seen the long term effects. Does this 6.2L; Also adding about 4k a year of my miles Rv towing, equal a higher quality filter?
Old 02-03-2014, 07:41 PM
BlueOvalJunkie11 BlueOvalJunkie11 is offline
BlueOvalJunkie11 is starting off with a positive reputation.
i just run a motorcraft filter and oil, i change mine every 5k and it always comes out clean, mine sees an rv every now and then
Old 02-03-2014, 08:31 PM
saratoga2011's Avatar
saratoga2011 saratoga2011 is offline
saratoga2011 is starting off with a positive reputation.
I can get a Motorcraft FL-820S for $3.50ish off the shelf at WalMart (right next to the orange filter brand), so it's a no brainer for me.
Old 02-03-2014, 09:41 PM
2014 f250 2014 f250 is offline
2014 f250 is starting off with a positive reputation.
I have always used Motorcraft filters on all my fords.Ford does not manufacture the filter,I think pureulator does,I am not 100%sure on that.But the Motorcraft filter is made to ford specs.
I am a tech at a honda dealer some of our honda oil filters are made by fram,they have a small fram stamp on the can.But they are made to honda spec and are different than the orange fram filter.
Filter media,bypass valves,and drain back valves can be different,and somtimes cause problems during cold starts and can cause drivabilty issues.
Old 02-03-2014, 09:42 PM
FordmanNJ's Avatar
FordmanNJ FordmanNJ is offline
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
FoMoCo FL820S and FoMoCo Semi Syn blend oil 5w20 from the local wally world.
Old 02-04-2014, 08:03 AM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
Quote:
I haven't done my first oil change yet but when I do and for the life of the truck its gonna be FORD OEM oil/filter as per manual. Being this was a FORD designed/built engine just for the SD they tested the truck using the FORD OEM products so I am staying with it to the bitter end, hoping 200k+ miles out of this engine....I did this with my 02SD 5.4 and she ran great until the day i traded her in..
Old 02-04-2014, 08:07 AM
JohnnyThunder JohnnyThunder is offline
JohnnyThunder is starting off with a positive reputation.
Always take mine to the dealer and have them do it. It gets whatever Ford called for for oil and filter and a free wash and interior cleaning.
Old 02-04-2014, 10:34 AM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
I use a Motorcraft FL-820S. If you look at the Purolater brand replacement, there's a difference in that the 820S has an extra O-Ring inside.
-Joe
Old 02-04-2014, 11:28 AM
King Rex's Avatar
Wow.. . Seems like an overwhelming motorcraft brand vote. Thanks for the replies. I have only owned the truck for 10 months, the dealership gave me my first few oil changes "on the house" due to some transmission issues they were trying to diagnose. All is good now, but, it is my turn to change the oil. I like to do myself, therapy I guess from the work day.
Old 02-04-2014, 11:46 AM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
Quote:
+1 ^^ THIS
That is exactly how I feel. I'm going to use what Ford says to use until the end of my days. I'm slowly approaching my second oil change after 15 months (not quite 10k miles yet). And it goes back into dealer for another free service when the time comes.
Old 02-04-2014, 03:56 PM
Stanggt24 Stanggt24 is offline
Stanggt24 is gaining momentum as a positive member of FTE.Stanggt24 is gaining momentum as a positive member of FTE.
Well I have a 2013 f-250 have owned it since March 23 2013 a special order truck I currently have 32,500 on truck . I use Mobil 1 full synthetic oil from Wally World and I use the napa gold oil filter which was recommended by my best friend who performs the oil changes. Motor is running strong so far.
Old 02-04-2014, 05:25 PM
fg250's Avatar
fg250 fg250 is offline
fg250 is starting off with a positive reputation.
x2 every 5000 miles.
Old 02-04-2014, 05:52 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
MC on everything except.....my wifes 1997 Cougar Sport (V8)...I use AC delco because it's about 1/2" shorter and a lot easier to change out......and our Mustang...the ol girl get a chrome Moroso filter!
Old 02-04-2014, 05:59 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
Motorcraft oil and FL-820s
After my research this is best overall option, IMHO.
Bullet Proof Diesel remote cooler/EGR cooler owners advice? gpm414 6.0L Power Stroke Diesel 0 11-21-2015 06:25 PM
No Oil in Filter Housing gmcbride 6.0L Power Stroke Diesel 4 03-23-2015 09:49 PM
2006 F350 86K just changed oil last week now random stalling HELP!' Frtdrmrose7 1999 to 2016 Super Duty 0 07-13-2014 10:03 PM
What Oil & Filter? SoYouCanSuperDuty Modular V10 (6.8l) 59 06-17-2014 10:22 PM
Fram Oil Filter for the 6.0: CH9549- Is it junk? whalerron 6.0L Power Stroke Diesel 35 09-26-2013 01:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
