Why is my por15 doing this
Yep POR 15 doesn't hold onto clean things well. My father and I are helping a buddy build a 76 Chevy and we're boxing the frame in. Inside his frame rails (slightly rusty) the POR 15 held great. But on the conduit we ran along the frame (to hold all the wires) the POR 15 just looked like it fish eyed all along it.
If you look at it that way i guess your better off not having it, the absolute best thing is to sandblast the item first, even if it is new, then paint with por15, done this many of times
on
WHAT IS THE BEST SURFACE ON WHICH TO PAINT POR-15?
POR-15 likes rusted surfaces best. Seasoned metal and sandblasted metal are also good. POR-15 does not adhere well to smooth, shiny surfaces, but will adhere well to those surfaces with the proper preparation.
WHAT IS THE 'PROPER PREPARATION'?
We make a product called 'Metal-Ready'. It's a rust remover that leaves a zinc phosphate coating on base metal, the perfect preprimer for POR-15. NOTE: New steel is coated with a protective oil finish at the mill. This finish must be removed before using POR-15 or Metal-Ready. Clean metal first with POR-15 Marine-Clean, then rinse with water and dry.
PREP & READYTM provides the best adhesion for POR-15® on any metal surface, including aluminum and shiny polished metal surfaces. Our simple process gently etches metal, creating an ideal anchor pattern for coatings such as POR-15®, while simultaneously leaving a zinc phosphate coating to insure chemical bonding of paint and steel. Avoid other preps that may leave harmful residues which prevent proper adhesion. After thoroughly degreasing your work piece, apply environmentally safe PREP & READYTM to both neutralize any rust and etch any clean bare metal. This will allow better adhesion of POR-15® or any other paint. PREP & READYTM is not caustic, corrosive, toxic or flammable.
PREP & READYTM before you coat your steel with POR-15 PREP & READYTM is an inexpensive insurance policy that guarantees perfect adhesion of POR-15 to any metallic surface every time.
I use POR15 kits on marine fuel tanks. It is awesome stuff but you HAVE to follow the directions to the "T". If you get the entire kit, it is 2 or 3 cans depending on the material you are applying it to.
It is also important to use the chemical etch to prep the surface...this is after you rinse it with water and let it dry and then wipe it down with acetone and let it dry. Using a heat gun after the final step helps alot
It lasts a very long time
It is a little pricey, time consuming to use but, if applied properly you will not regret it.
it says right in the instructions,,,,POR-15 does not adhere well to smooth, shiny surfaces.
a NEW gas tank is new and shiny last I checked. And also coated with an oil.
Brake drums are the same way, coated with a coating to keep them from rusting while sitting on the shelf
Hmm... I may look into painting mine with the Hi-Temp flat black I use to paint my exhaust tip with every now and again. I guess if it doesn't stick stick, I wouldn't really be out anything.
