1988 F250 7.5L engine issues
Yes, the acronyms can be confusing but you need to know what the documentation and we are talking about.
Prepare to be disgusted. After another hour of tracing down issues it is evident that I'm going to get to rebuild all of the wiring. I counted 7 fusible links and 6 places where someone incorrectly spliced in a wire.
With that said I did replace the negative cable from the battery to the engine block, replaced all spark wires, cleaned contacts in distributor cap.
Results afterwards:
all exterior lights coming on
dash lights up, no power to radio
AC Fan works
starter works
spark at distributor
rail fuel pump not coming on
engine turns over great
no fuel pressure
not a chance in hell it's going to start
Solenoid; hard to look at its so ugly.
Wiring mess on drivers side
Results afterwards:
AC Fan works
starter works
no fuel pressure
Sub, thanks for the feedback. I wont have a chance to test anything until this weekend.
In the meantime I have been shopping wiring harnesses. Here is the feedback received direct from their technical support.
Painless Performance: No, we don't have one that will work with that truck.
Ron Francis: Yes, we do have a kit. Use this one: XP-67 Ford Powered EXPRESS Wiring System-Ron Francis Wiring
They also have this kit for the fuel injection: FH-I460 1988 Ford Truck Injector Harness-Ron Francis Wiring
Broncograveyard: Nope, nothing and don't know anyone that makes them.
EZ Wiring: No, we don't have a kit.
I wired the fuel pump directly to the battery and still no start. Makes me think i also have an ignition issue.
Well, quick update on the truck and some advice needed.
Truck has been rewired and it runs again. It was quite a project and I'm actually excited to do body work.
Current Pic:
I'm currently trying to make sense of the vacuum lines. I'm hoping that someone can tell me the name of this piece? I have all the shop manuals but I just can't figure out what it is called.
This is it:
It had several broken lines but I simply can't figure out where they go. It does make great vacuum pressure when running.
I also have these three lines that come out of the firewall. The line on the far left is blowing air out to a tee which also had cut lines?
I do have the catalyst code and I have studied the vacuum routing sticker on the engine and the shop manual but I still can't make sense of it.
Any help is appreciated.
Bill D.
Current Pic:
This is it:
Bill D.
Sub, is it the man vac towards the front or back? I see two main vacs listed but I'm guessing it is the one shown in the back of the photo.
One of my other pictures is of three hoses that come out of the firewall. Can you tell me what the hose on the far left goes to? It currently has a T connector attached to it and both lines blow lots of air when the engine is running.
