2012 F250 - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
2012 F250
Old 02-03-2014, 12:54 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
2012 F250
Late last year I sold my old 7.3 (2000 model, 4x4 SC/LB, ZF-6) that had 307,000km on it. I had only just replaced the clutch, ball joints and a few other things, and she was a good truck. Although, I think the injectors needed to be replaced soon.
The reason I sold it was because living o/s I am allowed to take a vehicle back to Aus when I move back there if I own it and use it for 12 months overseas under the Personal Import Scheme. While the vehicle has to be RHD still, it skips a whole lot of the other red tape and BS that you need when importing a vehicle, and so works out to be a bit cheaper. It didn't make sense to throw 30-35 grand at a truck to convert it to RHD and ship it over to Aus, if it would only be worth 40-50 grand when it got there, so I sold it to get the newest truck I could afford, which look like they are selling for 140-150k over there.
I looked at all the options (and brands - even if I am a Ford bloke), and in the end it came down to a 2010+ Dodge Ram Cummins manual, or a 2011+ Ford 6.7
I liked having a Cummins (could get parts in Oz), having a manual, and they are much easier to work on than the cluster that is under the bonnet of the modern Fords, but the truck had a bunch of other shortcomings from what I read, so stuck with what I know. Found a used 2012 6.7 locally with 60,000 km on it that had a good price, and bought it.
The trucks have moved on a lot since the 2000 I owned (same mechanically as all the trucks sold in Oz). It rides a lot nicer, the engine and whole truck is really really quiet (sits at about 1500rpm at 110kph), it has no turbo lag, and on the hwy I have been averaging between 11-12l/100km. Steering and brakes are much better too. The electronics are pretty impressive, navigation, 9 speaker sound system, climate control, rear diff lock, heated and cooled seats. Although its a lot more to go wrong too, but short of a Range Rover, I don't know of a more comfortable offroad capable 4x4 in Oz. I definitely miss having a manual, vinyl hose out floors, and the while being quieter, the 6.7 doesn't sound anywhere near as good as the 7.3. This truck (a short bed) only has about 90l usable in its diesel tank, which is useless.
Since owning it, I have tuned it, fitted a straight pipe and removed the emissions systems (DPF, urea injection and the EGR), and according to the tuners dyno sheets it should have very close to 500 hp and 1400Nm at the rear wheels now. My bum dyno suggests it might not be quite that much, but it will light up the rear tyres on a dry sealed road at 60kph
I plan on lifting it 2" front and rear, and fitting slightly larger tyres on it once I wear these ones out, and have a few other changes planned too.
My parental unit will be flying over to the US to do a 3 month trip up to Alaska in it with a camper on the back to test her out.
As I go through the Personal Import and RHD conversion process towards the end of this year, I'll share the info here in case you guys ever go down this path.
Here are a couple of pics
Old 02-04-2014, 02:33 AM
Brad from Oz's Avatar
Brad from Oz Brad from Oz is offline
Brad from Oz has a good reputation on FTE.Brad from Oz has a good reputation on FTE.Brad from Oz has a good reputation on FTE.
Nice new ride Adrian,
Good thinking on getting max value out of the personal import scheme too. I saw a raptor for sale in a mag $120,000 !
Will you have to refit all the emissions gear to do the rego in Aus?
Old 02-04-2014, 12:12 PM
I don't think so (i.e. I hope not)
From what I have read, all it needs is a compliance plate from someone that is approved to check the RHD conversion process was done correctly, and then a roadworthy.
Old 02-04-2014, 08:07 PM
Ah, that sounds cool.
My crappy memory told me that it was different to the grey import RAWS scheme, and what you have read supports that. That's great news as going through the RAWS is hellish and the vehicle would have to be bone stock to get through.
Old 02-05-2014, 11:46 AM
I think all our importation laws are crazy, and to be honest the Personal Importation Scheme is the only sane way to bring a vehicle into the country (there isn't another country in the world that has vehicle importation laws like Oz - and part the reason I think vehicles are so expensive in Oz), but they have recently made the requirements quite a bit stricter.
Old 02-05-2014, 06:24 PM
Crazy - hell yes.
There is some hope, the productivity commission report into the auto industry just released has said that it's not viable to support auto manufacturing here, so highly likely the last player ( Toyota) will shut shop. But they also said that personal new and grey imports should be opened right up, possibly not to the open slather that NZ has though.
It will be nice to be able to parallel import any new car you wanted.
Old 02-12-2014, 02:36 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Thanks for that Adrian. I do believe the new truck is very impressive. Will be interesting to hear about the import/conversion process.
Old 02-12-2014, 04:19 AM
SSSimon SSSimon is offline
SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.SSSimon has a great reputation on FTE.
Brad, you were spot on about Toyota shutting shop!
It will be interesting to see how it plays out. The only reason it won't go open slather like NZ is that vested interests in the dealer network/s will lobby the Govt to keep taxing grey imports so as to protect the dealers current situation.
Old 02-12-2014, 07:49 AM
Yeah Simon, I agree it won't go open slather, my prediction is the current RAWS system and paperwork may be relaxed or streamlined somewhat.
The current dealers/importers would still have the advantage of factory direct supply and price, and factory warranty support.
Parallel import means you are now just pitting local dealers against O/S dealers and paying the freight etc.
Locally, well Ford were only selling one platform into a limited market, so that was never going to last. I predict they will shut early, even as early as end of 2014. They already have supply options to replace the Falcon & Territory.
Holden - they don't own the platform and importing the driveline from the US to fit to a local stamped body, then trying to export the driveline and body back to the US wasn't ever going to be cost effective. Since they pulled the Chevy badged product out of Europe there is a heap of available supply capacity in the Daiwoo factory in Korea which is earmarked for Aus. The next large sedan is apparently a Chinese design / build GM item. I predict Holden will go early as well, probably 2016 as they need time to tool up the US plants for the commodore platform.
Toyota is the sticky one, with so much of their build being exported they would need time to fill that from elsewhere, but seing they already make hybrid camrys in other plants it won't take them too long.
I used to think we should or could make specialist Natural Gas vehicles here as we have the supply capacity, but then yesterday I read that the Chinese are now paying such high prices for NG that the supply is all heading there now and we are actually in shortage in our own domestic system what a sad day!
Old 09-11-2014, 12:34 PM
Just to update this. About 3 weeks ago I submitted my papers to DOTARs, and received importation approval under the personal import scheme. Requires a bunch of paperwork, but now it is an online application and its a relatively cheap (~$60) painless process.
Once in Aus, I need to get a compliance plate made for it.
The truck is now at a workshop here that specialises in converting these vehicles. I'm told it will be a 6-8 week process to complete. Also plan on increasing the fuel capacity - for which I have an idea, we will see how it works out and I'll report back.
A few more changes to the truck as well. Fitted Bilstein 5160 shocks, Bilstein 7100 high mount steering damper, Firestone airbags with a wireless controller and airbag cradles, also a Viair on board air kit. New tires are required to register the truck in Aus too. I hope to have it over there before the end of the year.
Old 09-15-2014, 06:38 AM
Another thing Adrian, you said your new vehicle that you bought 2nd hand had 60,000K's on the clock. Was it a Canadian truck then - with K's on the clock? As I thought all the US units would be in miles rather than K's.
I do remember though on my one trip to the US, which was last century, to Seattle, my friend had a Ford T-bird, when we cross the border into Canada he pushed a button and hey-presto, all readouts where in K's! Maybe the new F series has the same feature.
Old 09-15-2014, 02:03 PM
It was 40k miles when I bought it, I just said Kilometres, coz I that's what the real world works in
The new trucks odometers can change between miles/kilometres (and other associated data tracking, like l/100km instead of (US)mpg) with a setting on the dash. The Speedometer has kmh already on it too - although mph is indicated with larger numbers. I'm not sure if the conversion process involves changing the speedo fascia to just have kmh - I had 500 questions for them, and forgot to ask that one.
Old 09-15-2014, 05:47 PM
Blue7.3's Avatar
Blue7.3 Blue7.3 is offline
Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.Blue7.3 has a great reputation on FTE.
Nice truck Adrian, hope it serves you well as the last one .
Long live the 7.3
Old 09-15-2014, 05:57 PM
Quote:
Originally Posted by Blue7.3 View Post
Long live the 7.3
If I ever have to work on this truck, I'll be saying the same thing. Under the bonnet, its a cluster...
Old 09-15-2014, 06:00 PM
Blue7.3's Avatar
Yeah you'll probably be lifting the cab
E350 Econoline RV Project conrod 1968-2013 Full Size Vans 46 07-14-2016 07:27 PM
Life gives you lemons..... Oz52F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 10-26-2015 07:20 AM
Advice on buying rodded 56 seeked NitroFreak 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 09-10-2015 03:12 PM
Amber turn signals for tail light - anyone make them? BigF350 6.7L Power Stroke Diesel 10 12-18-2014 06:56 PM
new to me 2004 F250, broken add-a-leaf plus other issues AAubinoe 1999 to 2016 Super Duty 21 08-01-2014 12:35 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford is a registered trademark of the Ford Motor Company.
