Australia Chapter Join Chapter , Leader: ChunderDownUnder
Got a Problem
Old 05-16-2015, 02:51 AM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
Old 05-16-2015, 09:13 PM
Aussie BrianB's Avatar
Aussie BrianB
Aussie BrianB is offline
Brian,
"Got a problem"
Bit of an understatement!
Going to be spending a bit of time getting your hands dirty I expect.
How is the other side?
Old 05-16-2015, 09:27 PM
ChunderDownUnder
the other side does have play but not as bad. the play in the axle tube has me concerned tho. Its all undone,just having a smoke before I get the hammer out to get the hubs off.
Old 05-16-2015, 09:37 PM
Aussie BrianB
I can think of a lot of better ways to spend a Sunday.
Best of luck with it.
Old 05-16-2015, 09:55 PM
ChunderDownUnder
Old 05-16-2015, 10:20 PM
Aussie BrianB
Ouch!!
Going to be spending more than Sunday on that by the loook of it.
Old 05-17-2015, 06:40 AM
Aussie BrianB
Brian,
Have you found what bit has given up the ghost yet?
Old 05-17-2015, 05:58 PM
BigF350's Avatar
BigF350
BigF350 is offline
I am guessing the wheel bearings are gone for one, but with the play on the axle shaft I am guessing the bearings in there are gone too (and probably the seals as a result). IIRC they are needle roller bearings.
How many k's you got on your truck Brian?
Old 05-22-2015, 06:48 AM
Patchy 73's Avatar
Patchy 73
Patchy 73 is offline
Mate, tried the link nothing comes up
Cheers,
Patchy
Old 05-22-2015, 07:43 PM
ChunderDownUnder
Do you have Windows Media Player. ?? Im assuming thats the problem.
Adrian. I have 225000 Kms. The drivers side bearing is toast. I could here some grinding while driving, thats what started the tear down. Im going to replace both sides and the needle bearings in the front diff. I cant seem to get the axle out at this stage. From what I read its a matter of hitting the back of the Uni joint but it aint working. Any ideas ??
Old 05-23-2015, 09:51 PM
ChunderDownUnder
what i think has happened is the vacuum seal has work it way through the housing towards the axle tube. Its a rock hard seal and wont push through because now its getting caught up on the inside lip of the housing.
Old 05-23-2015, 11:36 PM
ChunderDownUnder
Here is the vacuum seal in question
and this is what I had to do to get it through
Old 05-24-2015, 07:40 PM
BigF350's Avatar
BigF350
BigF350 is offline
You should be able topry the axle shaft out with a couple of big screw drivers on the lip like here:
225,000km is pretty early for them to fail. If you aren't planning on it already, I'd replace all the seals too, they get shot real quick after the bearings fail.
Old 05-25-2015, 02:14 AM
ChunderDownUnder
If only I had a pry bar. Mine is in the work truck which is not here. Anyways its out now. Now u say all the seals. I have the axle tube dust seals, the vacuum seals, what else. ?? Your not talking about the oil seals in the diff ??
Old 05-25-2015, 03:11 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
You only need the three seals , the axle seal FORD F81Z-3254-CB, SKF the big yellow one FORD F81Z 4A322AA and the axle dust seal FORD F81Z-1S175-HCA, plus you'll be fitting new needle roller bearings FORD C6TZ-3123-A , if you have auto hubs it may pay to re-new the o-rings on the auto hub assemblyFORD 4C3Z-1K106-AA.
Quick Reply: Got a Problem
