Roush F150 Upper Injector O-Ring HELP! - Ford Truck Enthusiasts Forums
Old 02-03-2014, 11:44 AM
ace555's Avatar
ace555 ace555 is offline
ace555 is starting off with a positive reputation.
I was installing a my new I/C Roushcharger kit over the weekend and ripped one of my upper injector o-rings (the one that seats to the fuel rail) , there-for having to replace. The problem is I CAN'T FIND IT ANYWHERE! I'm dying to start this beast but can't because of this issue!
My question is - I've read that the o-ring is the same style used in the 03-04 Cobras so I went to autozone and bought the o-ring (same one's used in the 04-08 F150s anyway) but this didn't work as a replacement due to the inside diameter being much larger than the injector "neck", so the injector just wobbled in the fuel rail!
Also, from what I understand, the injectors that came with my kit are in fact 38lbs NOT 39lbs like the cobras.
Here is the part # for the injector - R07110002 per Roush's instructions, if anyone has an idea at all of where I can find this 2 cent part I would greatly appreciate it!
UPDATED Fuel Injector Top O-Rings/Seals ~ The Whole Story creator 6.0L Power Stroke Diesel 123 03-28-2016 08:39 PM
Nipple cup replacement on 2003 log rail? basstardo 6.0L Power Stroke Diesel 10 02-24-2014 02:06 PM
HPO system Part #'s? lupuseven 6.0L Power Stroke Diesel 6 01-25-2014 11:03 PM
Can the hpo-rail leak enough to cause a no-start? John Irwin 6.0L Power Stroke Diesel 22 09-11-2012 09:11 PM
fuel injector o-rings Lennyg 1997 - 2003 F150 1 02-10-2012 12:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
