Are all 53-56 grilles interchangeable, what about headlight rings? - Ford Truck Enthusiasts Forums
Old 02-03-2014, 07:53 AM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
Will all the grilles interchange?
I prefer the 55 grille over the 56 and would like to use it.
Will my 56' headlight buckets work in the 55 grille?
Will my "inny" trim rings work on the 55' grille?
Old 02-03-2014, 08:37 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
There are differences in the gravel pans and air deflectors over the different years.
The '56 air deflectors have depressions for the headlight buckets due to the recessed headlights.
The '53 uses one gravel pan, the '54 uses a different one (due to the shape of the grille) , and the '55 and '56 use a different one. It has to do with the running lights and their position.
You can use the '55 grille on the '56 truck without any problem. If you want to use the '56 headlight rims, you will have to use the '56 air deflectors and will have to "French" (recess) the headlight buckets. I've seen it done but I don't know the details.
Edit: Here is a thread where someone here on FTE Frenched the headlights on a '53 grille. I hope this helps answer your questions. http://www.ford-trucks.com/forums/10...dlights-5.html
Old 02-03-2014, 01:08 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Take a look at this thread http://www.ford-trucks.com/forums/10...eadlights.html, I believe that all your questions will be answered there. Post #65 has some good info on the bolt patterns, that was a gotcha I missed when I decided to go with a 53 grille in my 56. Going from a 56 to a 55 may not have the same bolt pattern issues but it is worth while to look before you leap.
Old 02-03-2014, 01:14 PM
There isn't a post 68?
Old 02-03-2014, 01:43 PM
dav54effie's Avatar
dav54effie dav54effie is offline
dav54effie has a good reputation on FTE.dav54effie has a good reputation on FTE.
I noticed on my truck that the bolt patterns aren't the same for 55 to 56. The po had one deflector from a 56 and one that was original. When I put my 55 grille on the for test fitment, the 56 deflector wouldn't bolt up bc the bolt holes were in different spots. I don't know if mine are made different or what but that's how mine is.
Old 02-03-2014, 02:23 PM
I knew there was a difference between the '53 and '56 grille-to-deflector bolt pattern, but I didn't know about the '55. It's easy enough to drill the correct holes, but be sure to plug the extras. Otherwise the front tire will be throwing water, mud, and grit behind the headlight bucket. A sure recipe for rust.
Old 02-03-2014, 08:32 PM
dav54effie's Avatar
I don't think about that! Ima plug mine up when I get back out to it. It's a little to cold right now.
Old 02-03-2014, 09:57 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is online now
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
Try this link to my tech week submission on the Hamb
Tech Week....Eye Surgery for the 53-55 F100 Grilles - THE H.A.M.B.
Old 02-03-2014, 10:09 PM
Thanks fellas, now I just have to find a reasonably priced 55 grille!
Old 02-03-2014, 10:25 PM
dav54effie's Avatar
I found mine on eBay after watching it like a hawk for about two or three months. Little rusty but good condition. Good luck!
53 Grille with 56 Headlights CharlieLed 1948 - 1956 F1, F100 & Larger F-Series Trucks 73 11-21-2015 02:40 PM
53 Headlight buckets, 56 Grille, 53-56 air deflectors??? Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 10-30-2015 02:29 PM
Are all 53-56 Grille supports the same? clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 02-26-2014 08:24 PM
56 Headlight Trim in 53-55 Grilles Drewski 2 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 03-06-2012 01:16 AM
Headlight bucket questions 53OlderThanMe 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-23-2009 08:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
