Radio issues 2008 Expy - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 02-02-2014, 09:09 PM
dsprenger30 dsprenger30 is offline
dsprenger30 is starting off with a positive reputation.
I have a 2008 Expy the radio w/o nav keep reseting Text reading "sirius ready" turning off and on and cd changer keeps cycling??? I pulled the fuses to try and reset?? batt next?
Old 02-03-2014, 12:18 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Yeah, I would try that. Sounds like a glitch in the radio. If that doesn't work try putting the radio into test mode.
Summarized from the Ford Service Manual:
Speaker Walk-Around Test:
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
1. To enter the speaker walk-around test, simultaneously press and hold the audio unit preset buttons 3 and 6 for approximately 3 seconds, then release.
2. The speaker walk-around test applies sound to each speaker for about 1.5 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR.
Audio Unit Self-Diagnostic Mode:
• NOTE: Always document and clear DTCs and carry out the audio unit on-demand self-test again.
1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
2. To exit the audio unit self-diagnostic mode, turn the key or the audio unit to OFF.
3. The audio unit self-diagnostic mode has 5 tests available:
• Preset Button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll through the DTCs stored. Refer to the Audio Unit DTC Index. If the system is OK, SELF PASS will be displayed.
• Preset Button 2 = View/Clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the Audio Unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
• Preset Button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting. ** Perfect for testing antenna types and position changes. **
• Preset Button 4 = Software level query. This test queries each audio system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
• Preset Button 5 = DISPLAY TEST. This test will light all the audio unit display segments for 5 seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
5. To exit the self-diagnostic mode, press the power button on the audio unit or turn the key to the OFF position.
Audio Unit DTC Index:
DTC - Description - Action
B1317 - Battery Voltage High - CHECK the charging system.
B1318 - Battery Voltage Low - CHECK the charging system.
B1342 - ECU Is Faulted - CLEAR the DTC. CARRY OUT the self-test. If DTC B1342 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility.
B2406 - Audio Disc CD Player Internal Fault - CLEAR the DTC. CARRY OUT the self-test. If DTC
B2406 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility.
B2477 - ECU Configuration Failure - CLEAR the DTC. CARRY OUT the self-test. If DTC B2477 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility. REFER to Section 415-01 . TEST the system for normal operation.
B2924 Audio Button Stuck INSPECT the audio unit for a stuck button and REPAIR the concern, if possible. CLEAR the DTC. CARRY OUT the self-test. If DTC B2924 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility.
B2965 - Audio System Speaker Circuit Fault - See Ford Factory Service Manual for troubleshooting steps
Old 02-20-2014, 10:17 AM
cstanley44's Avatar
cstanley44 cstanley44 is offline
cstanley44 is gaining momentum as a positive member of FTE.
My Explorer did things very similar
A few days later, the truck would not start - battery was dead
Got a new battery and symptoms went away.
Seems a weak battery can cause strange things
Easiest thing is to swap out with a known good battery before you buy another.
'11 Expy Limited entertainment screen out haviland 2007 - 2014 Expedition & Navigator 7 08-31-2015 09:36 PM
2008 F250 Nav Radio Problem damada Ford In-Vehicle Tech 7 01-23-2014 02:17 PM
2008 F250 Nav Radio Problem damada 1999 to 2016 Super Duty 12 07-17-2013 10:10 AM
? on the SAT radio in a 2005 Expy dr cabela 1997-2006 Expedition & Navigator 5 12-22-2012 08:49 PM
Radio reset code? Dutch123 Electrical Systems/Wiring 3 04-22-2005 07:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
