MANIFOLD CHANGE
Old 02-02-2014, 02:47 PM
money pit 69's Avatar
money pit 69
money pit 69 is offline
MANIFOLD CHANGE
Hello all, I'm getting ready to change out manifolds on my 69 390. 2 barrel to 4 barrel cast. Is there anything I should be aware of that might make this a bad experience. I've heard something about oil pump shaft and silicone at the rear corners. Any other hints would be appreciated. THX David GO HAWKS
Old 02-02-2014, 03:59 PM
MIKES 68 F100's Avatar
MIKES 68 F100
MIKES 68 F100 is offline
weight of cast iron manifold ! I've heard others say use a engine hoist to lift manifold if it's stuck to the engine after bolts are removed.
Old 02-02-2014, 04:05 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Go Broncos!... only cuz the Seakocks took out the Niners!
2v to 4v swap....
You may need a single-port manifold fitting: https://www.ford-trucks.com/forums/1...l#post13559606
Have a helper to assist in removing the old manifold and to install the new one. Them iron beasts weigh 82 lbs.
Installing a new thermostat? Drill a 1/8-inch hole on the thermostat flange and install it with the hole at the 12 o'clock position. This will allow trapped air to escape when filling the cooling system.
Replace the bypass hose.
Holding the thermostat in the thermo housing's recess is dang hard and tends to slip outta position. I applied small dabs of RTV to the thermostat and "pre-glued" to the thermo housing, let it set, and then installed it on the manifold.
Ditch the cork "China wall" gaskets and use RTV. Prepare the China walls with small dimples so the RTV has something to grab onto instead of a slick, smooth surface. It should look like this:
Good luck and GO BRONCOS!
wattspd
13
01-18-2018 02:45 PM
Frdtrkrul
10-30-2017 12:10 AM
oldmansimek
01-18-2006 11:11 AM
oldmansimek
01-11-2006 10:03 AM
Tesch101
11-08-2005 08:52 AM
Quick Reply: MANIFOLD CHANGE
