54 mod f100 4.6l - Ford Truck Enthusiasts Forums
54 mod f100 4.6l
Old 02-02-2014, 01:53 PM
99hicksf350 99hicksf350 is offline
99hicksf350 is starting off with a positive reputation.
54 mod f100 4.6l
My build is a 54 f100 with 4.6l dohc from a 94 mark viii, using motor trans and rearend form the lincoln. I used a TCI mustang II front end, and the lincoln irs with brackets I made to fit. I'm currently fishing through the engine wiring to make it run.
Old 02-02-2014, 01:57 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
Sounds like a nice project and should be fun to drive when done. A couple of others here are doing the same (gregstith and Project-55, I believe).
Just remember, without pics it didn't happen
Old 02-02-2014, 03:33 PM
[/IMG]
Old 02-02-2014, 04:40 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Nice start!!
Old 02-02-2014, 05:00 PM
If I could only get the other pics to load...
Old 02-02-2014, 06:00 PM
DW SD DW SD is offline
DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.DW SD has a very good reputation on FTE.
I've had to load only one picture per entry / reply..... Try that maybe. Good luck either your build!
Old 02-03-2014, 06:06 AM
dmack91's Avatar
Nice stance. Sounds like it should be entertaining to drive. Nice work.
Old 02-03-2014, 08:10 AM
clintonvillian clintonvillian is offline
clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.clintonvillian has a good reputation on FTE.
Man that thing is low, what kind of suspension is under it?
Old 02-03-2014, 08:16 PM
snook715's Avatar
snook715 snook715 is offline
snook715 is starting off with a positive reputation.
Mustang II front with the Lincoln IRS rear, yes?
Old 02-03-2014, 09:24 PM
Yes Mustang II with 2" drop in front, Lincoln IRS rear all bagged that is aired down, not at ride height
gregstith's Avatar
gregstith gregstith is offline
gregstith is gaining momentum as a positive member of FTE.gregstith is gaining momentum as a positive member of FTE.
Old 02-03-2014, 09:25 PM
gregstith's Avatar
Quote:
Old 02-03-2014, 10:26 PM
[/IMG]
Old 02-03-2014, 10:28 PM
[/IMG]
Old 02-04-2014, 12:14 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Welcome 99hicksf350,
What size are those rims and tires? Got any more pictures of the IRS install?
4.6 liter install in 53-56 F100 anyone do it? Crazydan 1948 - 1956 F1, F100 & Larger F-Series Trucks 46 09-18-2014 02:54 PM
4.6 liter install in 53-56 F100 anyone do it? Crazydan 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-18-2012 12:31 AM
4.6L SOHC to 4.6L DOHC? MEFFORD 1997 - 2003 F150 16 01-02-2010 08:32 AM
mod motor for 56 f100 project, 4.6 or 5.4? sdetweil Modular V8 (4.6L, 5.4L) 8 07-08-2009 12:14 AM
4.6, Cast Iron or Aluminum? mantta Modular V8 (4.6L, 5.4L) 1 02-13-2004 01:42 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
