Limp mode - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Limp mode
Old 02-02-2014, 01:39 AM
colodan colodan is offline
colodan is starting off with a positive reputation.
Limp mode
Just got truck (2008 6.4L, 100,000 miles) out of shop for DPF problems. Was told it is just my driving habits and to be sure to change oil more frequently. I don't drive the truck much at all, maybe on average about 10 miles a week as I have a company vehicle I drive to work. In the summer it does pull my trailer (30' 5th wheel) whenever I can get away, which hasn't been much lately. It was going into regen about every 20 miles. I do get it on the highway and drive it till it finishes,(actually put more miles on it to clean then I do driving it where I need to go) so that is why I brought it in. They changed the oil, told me it was about 3 quarts too high and gave it a new flash that they said would probably help. drove it home, had to go to store next morning, but "drive to clean" came on as soon as I left driveway, so headed to highway before store. On the way to high way, a wrench symbol started flashing( this is new, figured was new flash). got on highway and it went into regen shortly after. no more wrench symbol and finished regen... actually got 90 miles(25 of which were driving back home from cleaning) before the drive to clean came on tonight. didnt have time to get on highway and wasnt going too far. about 3 miles after drive to clean came on, wrench apeared again right as i was about to park at my destination. Parked truck, took care of my business, about 3 hours later got back in to head home. still had warning messages, so started heading for highway, before I could get there it went into limp mode, so just had to limp home. I'd rather get on highway every 10 miles then take it to shop every 90. I don't know what to do next, besides obviously take it to shop on monday when its open. not sure I want to do the dpf delete as I don't want to have to put it back on evey time i need to get emmisions. I love my truck when pulling the trailer and just got a second car to drive around town. However I would like to be able to drive truck around town sometimes as well, especially in snowy weather. My other car is a mustang gt, not the best winter car....any suggestions on what is going on with truck and what I should do? also is it safe to drive it to dealer in limp mode? About 10 miles away. keep in mind I already put 5 miles or so on limp mode getting home tonight.
Old 02-02-2014, 10:53 AM
GSchretter's Avatar
GSchretter GSchretter is offline
GSchretter is gaining momentum as a positive member of FTE.
Sensors are probably bad. Time to move toward DPF delete.
Have you pulled codes yet?
Be careful the heat created from that many regen will hurt your motor.
You can do DPF delete for around $1200 (that's with the DPF delete pipe)
PM me if you are interested. I don't sale anything but I will forward you info who does and stuff.
Old 02-02-2014, 10:56 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
you can take it back to the shop but in the end with you short driving distance it needs to be tuned. Otherwise it will be like it is, don't get me wrong it should be better than it is but it will always be a hassle to say the least.
Old 02-02-2014, 11:11 AM
If I do the delete, is it something I have to put back together to get emissions?
The dealer said it was giving no codes.
Old 02-02-2014, 01:28 PM
After finding and reading a lot of threads on here about the dpf delete, I agree that this is probably my best option. Just hope I have not already done any damage to motor by going into regen so much. My question now is since truck is in limp mode now, do I have to take it to dealer to have that cleared before I put on the dpf delete kit? I believe I will have to go back to stock for emissions so my concern is will it just go right back to limp mode when returned to stock? also any advice on the best kit to get would be appreciated.
Old 02-02-2014, 02:12 PM
bubbasz1's Avatar
Well, your out of warranty correct. It would be nice if you could get the cleaning cycle fixed, could just be a simple sensor, who knows without a little troubleshooting. And yes you will have the problem when you go back to stock to pass emissions. What do you have to do for emissions??
Anyways the most economical that I know of is this. I don't have it so I can't vouch for it but guys on the sight use it without issue.
(GBZ-FKKTPAFE) GBZ - Tachyon Plus Tuner for Ford 6.4L With aFe DPF Delete Race Exhaust
Old 02-02-2014, 04:10 PM
It is out of warranty so no concerns there. for emission test I have to take it to a state certified shop and they test it, not sure what the test entails though, but results are sent to dmv and need a passing emissions in order to register/renew plates. I will check out the link you suggest, and thanks for your help. I guess I should take it to dealer to try and get limp mode sorted in the mean time.
Old 02-03-2014, 11:28 AM
Thasilver_6.7's Avatar
Thasilver_6.7 Thasilver_6.7 is offline
Thasilver_6.7 is gaining momentum as a positive member of FTE.Thasilver_6.7 is gaining momentum as a positive member of FTE.
I would really consider going to a different shop/dealer...if your getting different symbols and you know the truck isn't right.. yet there still not wanting to help! when I bought my truck 8 months ago.. I didn't know what deleting was.. I just got the truck I was happy.. but the more I found out..if you keep the emissions on.. doing just short trips here and there.. or always light driving.. it's going to be on-going problem...those engines are built to work hard.. and keep going.. just a couple thoughts.. I had my truck deleted....haven't looked back.. 8 months later one of the best trucks I've ever driven!
Old 02-03-2014, 04:01 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
My truck seems to run better and use less fuel around town and on short trips more than on long trips.
I think its because Im going slower?
Old 02-03-2014, 06:55 PM
bubbasz1's Avatar
that's because yours is a 450 with a tall gear
Old 02-03-2014, 07:24 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
You can try blowing out some ash from the DPF if you have it off for any reason. That should lengthen the time between regens if the DPF being full is the problem. The DPF is supposed to last 125K miles before cleaning is needed.
Old 02-03-2014, 07:58 PM
OK, just got back from dealer. now that it is in limp mode(and my guess because it is out of warranty), it is giving codes. Apparently -0128- thermostat is stuck open, P2463, P246C DPF clogged, P042F EGR valve stuck closed......They want $800 for PPT(what is PPT) & replace Stuck egr valve & Housing, $425 to replace T-stat, $330 for Iron cleaner flush cooling system, and $119 to attempt a manual regen...If manual regen doesnt work, they want $2200 to replace DPF...... I told them to do nothing and I took truck back home. It makes sense to me now because the truck just wasn't getting hot enough to do a proper regen...I am no mechanic by a long shot, but I have friends willing to help, is all this stuff something that I could do myself for I'm guessing 1/4 of what the dealer wants? I am still planning to do the delete, but I will have to go stock for emissions or if I ever want to sell....Is it something I could do delete first and buy parts slowly before I need emissions in a year and a half? Thanks for any and all help guys....EPA sucks!!!
Old 02-03-2014, 08:28 PM
bubbasz1's Avatar
Yep, Start looking for a DPF in Craigs list or EBAY, thermostats are easy<>more or less. Get a tuner that deletes EGR and DPF. Start looking for a takeoff egr valve same place AS THE DPF, and if you have to go back stock in a year and a half you should be ready. One big reason your having an issue with the DPF is a stuck closed EGR.
The cooling system flush will be the biggest hassle as far as I'm concerned. Getting rid of all the flushing stuff and old antifreeze will be a pain.
You probably won't want to sell after your done deleting. :}
Old 02-04-2014, 02:04 AM
It's amazing what the dealer does once the warranty is up. :-(
Regens won't start until coolant is >160F. If the thermostat is stuck open, I'd think the truck will have problems getting up to temperature. However you said regens completed ok, so I'm not sure a manual regen would do anything.
I'd think a stuck closed EGR is a blessing. One that is stuck open can result in more soot and lack of power. Supposedly, you can try pulling out the EGR valve and clean it. Not sure if anyone has done it here, but I hear it's a pain even with a puller.
It's possible the DPF pressure sensor is marginal or the tube that is hooked up to it is leaking. That should be a quick one to check.
The only other potential cause would be a stuck injector.
I'd try dropping the DPF and blow out as much crap as you can with a shop compressor preferably after a regen (less soot to keep things stuck together). That'll buy you some time if it's actually bad. I got a half of a small sandwich baggie of black ash out from mine at 30K miles. Miles between completed regens increased by 50-75 miles right away.
[post-edit] Don't drive around in limp mode. When the DPF is fuller than the point where it needs to regen and can't start a regen, it goes into limp mode. It will eventually plug up completely to the point a regen cannot possibily work and leave you stranded waiting for a new DPF
Old 02-04-2014, 02:14 PM
bubbasz1's Avatar
I was just re-reading what they quoted you, crazy numbers, 425 to replace thermostat's.
Two big issues I see on your list of codes is stuck open stat and stuck closed EGR, they go hand in hand during a regen.
Dealer and Automatic Regen: how does it work? my50F1 6.7L Power Stroke Diesel 22 09-29-2016 07:48 AM
Frequent Regens - Clean the DPF? Aaron Green General Diesel Discussion 21 03-09-2016 12:20 AM
2015 f350 regen issues badgeking 6.7L Power Stroke Diesel 22 09-21-2015 01:02 AM
REGEN Kamstutz 6.7L Power Stroke Diesel 27 03-14-2015 03:17 PM
are short trips going to be a problem bullit340 6.7L Power Stroke Diesel 9 10-19-2014 08:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
