Engine Stand
Mine was on the stand for over two years as well.
My stand is a home made thing, with only three legs and no wheels, so it doesn't get moved around. If I move it at all it's with the hoist. I think next project I'm going to weld a piece across the front to make it's footprint an "H" instead of a "T".
http://www.35pickup.com/mulligan/weight.txt
It's real hard to compare weights. There is a listing that has been on the internet for 20 years, but it is 90% anecdotal numbers (what someone told the guy making the list). So some weights are for an engine with heads, intake manifold, exhaust manifolds, starter, generator, carb, etc. and others are for partially stripped engines. Who knows what the basis for some of them is -- shipping weight on a pallet?
I've heard (anecdotal info!) that the Y-blocks weighed less than flatheads because they have a 5-main bearing crankshaft with smaller counterweights. But then their heads must weigh more?
I seem to remember somewhere in the deep dark recesses of my mind a caution to not mount flatheads by the rear flanges as they could break. I can't remember the years might be earlier ones. It was recommended to mount them by making brackets from the stand out and bolting them through the exhaust ports. Does that ring a bell with anyone?
NOTE: the above is per the word of the Internet and hours and hours of bench racing
maestro1024
21
03-25-2013 08:01 PM
mOROTBREATH
16
03-29-2009 11:35 PM
siphor84
10-19-2003 12:30 PM
