No heat
No heat
For a while I have had no heat and I thought it was the blend door that is the problem. But I have adjusted the blend door so it should be closed and the air that comes out is cold. It's not as cold as the outside air but it doesn't feel warm at all. Is there something else I should be looking at?
on
Detatch the heater core lines and force some water through the core in both directions until it flows clear. I have seen some nasty looking gunk come out of a heater core when doing this and it always makes a difference in the amount of heat you get in the cab.
A test for a clogged heater core is once the engine is at operating temp put your hand on the two heater core lines to see if there is any temperature difference, there should not be a big difference, one maybe slightly cooler but both should feel warm.
Today I checked the heater core for clogs by removing the hoses. No clogs, I was able to blow through the core with no problems, and the coolant was the same color as the coolant in the radiator. So it's got to be the blend door, I guess. I'm sick of not having heat so I'm gonna figure this out.
Its really a pretty simple system, if the blend door is working properly, then it almost has to be a low/no flow problem.
I have friends in Denver. I'm not a Seahawk fan, but nonetheless I'm going to leave them alone for a couple of days lol...
