windshield washer won't spray - Ford Truck Enthusiasts Forums
Old 02-01-2014, 02:11 PM
Jarryd's Avatar
Jarryd Jarryd is offline
Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.Jarryd has a great reputation on FTE.
My Washer fluid won't spray when I got the button. The wipers come on but nothing is coming out of the nozzles. I'm guessing the pump is probably seized up but I'm not sure where to check first and I don't know where exactly the pump is without digging around to find the thing.
Old 02-01-2014, 03:33 PM
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
The pump is located in the bottom of the fluid reservoir. Pull the reservoir out, remove the pump and test it first. I thought mine was bad but it turned out to be corrosion in the connector. A good cleaning and a dab of dielectric grease and I have had no issues in over a year.
Old 02-01-2014, 03:56 PM
Big_Al59 Big_Al59 is offline
Big_Al59 is starting off with a positive reputation.
Thought mine was bad & then noticed I had the summer fluid in it and it was froze. Put it in heated shop for a couple hours and it worked fine. Drained out old fluid & filled with winter fluid.
Old 02-01-2014, 03:57 PM
broke vet broke vet is offline
broke vet is gaining momentum as a positive member of FTE.
Quote:
Been there done that. Just last month, as a matter of fact.
Old 02-01-2014, 04:14 PM
Jarryd's Avatar
It's 60 outside. I don't think that's the issue. That was my first thought because it was -8 last month. Oh ky. I love your bipolar weather.
washer nozzles meborder Expedition & Navigator 1 01-29-2016 11:37 PM
windshield washer connector, no power ? mike L 1987 - 1996 F150 & Larger F-Series Trucks 12 05-29-2015 05:19 AM
1986 washer fluid/coolant reservoir debacle SVTDriver97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 29 05-28-2015 04:25 PM
Front Windshield Wiper Washer Problem k7ikuzus1k Excursion - King of SUVs 4 06-25-2008 02:31 PM
spider gear thrust washers mxzx Offroad & 4x4 5 05-16-2008 11:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
