Ok try one more time. 06 F250 5.4 with p0174 &p0171 - Page 2 - Ford Truck Enthusiasts Forums
Old 02-25-2014, 09:16 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Originally Posted by jkinghorn6.0 View Post
I just got code p2112. Anyone get this code before
Here's what the Actron Code Lookup site says about P2112: Throttle Actuator Control System - Stuck Closed
Old 02-25-2014, 11:01 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
The codes P2112 and P2104 are in most cases caused by a eaither the connection to the throttle body motor and or a bad throttle body motor itself. I would start with making sure the connector is clean and tight and if so then you are likely going to have to replace the throttle body assembly. In most case its the throttle body assembly as the motor is not serviced separate.
Old 02-26-2014, 12:58 PM
jkinghorn6.0's Avatar
jkinghorn6.0 jkinghorn6.0 is offline
jkinghorn6.0 is starting off with a positive reputation.
I was planning on replacing the motor over the weekend It doesn't look like it would be very hard. I was going to replace the throttle body gasket to rule out any vacuum leak at the throttle body and give it a really good cleaning cause its really dirty.
Old 03-02-2014, 06:57 PM
I replaced the throttle body motor and gasket cleaned the throttle body and I'm left with the lean codes still. Dose run nice though. Changed the oil and fuel filter. I get between 38 psi and 40 psi fuel pressure. I live in south jersey. What should my BARO, MAF, throttle position, vacuum and timing be at idle if anyone knows?
Old 10-29-2014, 02:08 PM
ck1iceman ck1iceman is offline
ck1iceman is starting off with a positive reputation.
P0174 Issue
I am also having trouble with a P0174 Code and am seeking advice. First off, I did a no-no and washed my engine. I've done it before but always drove immediately after to dry things out. This time it sat for about an hour before a quick trip for breakfast. Next day and the past few days its been idling rough and feels like it missing on a cylinder or two. The only code I get is P0174 System Too Lean (Bank 2). Wouldn't I gets code for both banks being lean if I had a vacuum leak or MAF issue? I did check the MAF and cleaned it with electrical cleaner. Also checked the first couple of COP to see if water had filled the spark plug hole but all I found in there was dielectric grease. I not getting any codes for misfires. I've checked all the vacuum lines and fittings I can reach and all seem to be fine. I'm rally at a loss now. I'd hoped that if moisture had gotten into something it would have dissipated by now several days later she's still running like crap.
Old 10-29-2014, 06:50 PM
Well i had that code then I ended up with both. My intake gaskets went bad and i had a vacuum leak in the intake. I replaced the intake and gaskets and haven't had a problem since. I took it to ford and paid the 100 bucks and got a definitive answer. I bought both ( intake and gaskets) from ebay for 320 total
Intake manifold bill4x4 1997-2006 Expedition & Navigator 4 03-07-2014 12:35 PM
# 6 Misfire Plumbin 1968-2013 Full Size Vans 4 09-24-2013 06:50 AM
Ford 5.4 Fel Pro exhaust gasket install question steveterryrudy 1997-2006 Expedition & Navigator 2 03-10-2012 09:01 PM
06 250 P1633 code nealneu 1999 to 2016 Super Duty 1 03-30-2011 11:15 AM
5.4L3V Engine Iceman21 1997-2006 Expedition & Navigator 6 06-23-2006 01:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
