Check Engine Light On
I am recent owner of a 2001 Excursion LTD 4x4 w/ 7.3L I love this ride. I bought this truck to tow my 8500lbs camper. We traveled all the way across the country to the North Rim of the Grand Canyon from Florida. My check engine light came on shortly after started towing the camper. I pulled into a local auto part store to pull a code. They were no help. The code said Bank 1. ???? After we unhooked the camper in AZ and drove around for a while, the light went off. Any suggestions will be greatly appreciated.
If you knew what code it was exactly that may help instead of just bank one. You can buy a code reader as well they usually run between 70-1000s depending on what type you can get.
I went for the option of a scangauge 2,which attaches to your obd2 port and can give you useful information like trans temp, cylinder temp, intake temp, mpg, load, throttle position and the list goes on. This cost me around 160$. And is a universal code reader.
Sent from my Galaxy using IB AutoGroup
This is the scanner I bought.
OBDCOM Diagnostic Systems for ALL vehicles
You do need a computer (I use a simple notepad computer) to use this. Others are self-contained, and there are a bunch now that interface via Bluetooth to your cell phone via an app on your phone and a small plug-in device.
https://play.google.com/store/apps/d...l.torque&hl=en
