I cut the glass for my chop top today and........... - Ford Truck Enthusiasts Forums
Old 01-31-2014, 06:53 PM
clintonvillian clintonvillian is offline
clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.clintonvillian has a very good reputation on FTE.
IT BROKE! HAHA
BUT
Now, I had nothing to lose. The glass was delaminating around the edges and I am buying new anyhow. I called a guy (Chris Blattie) to cut it for me and is sure he can he just needed a paper template. I will fit my cab to the glass I cut. and then make a paper template and mail it to him for him to cut.
I called my local guy and he assured me it would break if he cut it down for my template, and was going to charge me 50.00 bucks to do it.
I thought I can do it myself, and was going to order a glass wheel/pen. Then it dawned on me, back when I did construction we used to cut glass wheels with a diamond blade on a grinder when we had tight spots, so why wouldn't it cut a windshield......well it does and did
I was doing it outside in 30 degree weather, the glass was really old and brittle, I was using a cheap blade, trying to hold a water hose and an angle grinder at the same time, I was in a hurry, and it was nearly dark.
So I come away with this, It is possible to cut a windshield with the grinder and diamond blade. I will probably try my own instead of paying someone else to do it. Had I had someone holding the hose so I could have controlled the grinder I wouldn't have cracked this one. And it can be done within about 15 minutes
I taped it off
used this blade
taped it off
and cut it
Old 01-31-2014, 07:19 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
You are going about the chop in the correct manner...cut the glass and THEN match the roof to it. As you can see the point where the glass meets the roof is considerably forward. The good news is that the 56 roof has enough "brow" to compensate for the new position of the windshield. Good luck with your project!
Old 01-31-2014, 07:28 PM
56panelford's Avatar
56panelford 56panelford is online now
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
You are braver than I am, not in the fact that you cut the glass but the attempt of chopping a 56 or anything with the wrap around windshield. I may be wrong but there looks like there will be a rather large gap at the top of the glass when the roof is lowered. I've tried visualizing this many times and why I'd be afraid to try it. Waiting to see how it turns out. Another reason why I think I'd not attempt it is because of the agony of having to do it all over again should a flying rock makes contact with it in the future which would be my luck.
Old 01-31-2014, 08:17 PM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is online now
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
I was wondering about cutting a windshield now I know! Looks like you're on your way to a chop top 56.
Old 01-31-2014, 10:43 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Good bit of info
You're a brave man.
I wonder if that blade might cut better if it were mounted in one of those small circular saws instead of an angle grinder. I don't know, its just and idea
Bobby
Old 02-01-2014, 12:05 AM
Project-55's Avatar
Project-55 Project-55 is offline
Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.
very cool information, I had never thought of starting a chop job by cutting the glass first but after just a moments thought it makes perfect sense. Thanks for educating me today.
Old 02-01-2014, 09:25 AM
Posting Legend
Where does the glass end up after the chop? Looking at the side picture it would seem that the glass would be about 3/4'' to 1 " away from where it's supposed to be.
Old 02-16-2014, 08:17 PM
56, you are right. The solution is to sand off the back upper edge of the wing, and lower bottom edge of wing to allow the glass to roll back.
I have decided not to do the chop. I really like the look of the flattened roof with the stock height cab as I have done.
Old 02-16-2014, 08:32 PM
toby tough's Avatar
toby tough toby tough is offline
toby tough has a good reputation on FTE.toby tough has a good reputation on FTE.
Not only brave but wise also. I would be shakin' in my boots for sure.
Old 02-17-2014, 01:32 PM
Posting Legend
I think you have made a very wise decision, you could end up destroying many windshields before you get one to fit properly and only risk having to do it again if it were to ever get broken in the future.
Old 02-17-2014, 01:46 PM
Drewski 2's Avatar
Drewski 2 Drewski 2 is offline
Drewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud ofDrewski 2 has much to be proud of
Even though I chopped my 55, I think you made the right decision on the 56. I've always thought the 56 was perfect as it came.
Windshield Installation old_dan 1948 - 1956 F1, F100 & Larger F-Series Trucks 45 05-04-2014 04:10 PM
Henry's Method of door gap alignment, you guys will love this! clintonvillian 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 02-17-2014 06:32 PM
Bored. So I took some pics. hammerhead90 1987 - 1996 F150 & Larger F-Series Trucks 32 08-28-2011 01:40 AM
My 5" miter cut stacks with pics fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 34 08-27-2011 01:03 PM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
