new truck no start below 0 degrees - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 01-31-2014, 09:26 AM
Glwhope Glwhope is offline
Glwhope is starting off with a positive reputation.
Question new truck no start below 0 degrees
New 2013 F250 6.2. 370 miles.
Two mornings in a row -2 out and go to start, turn the key and just a small tick sound. Turn off the key and turn on again and fires right up. This happened twice when below 0. Any thoughts?
Old 01-31-2014, 09:43 AM
Go Big or Go Home! Go Big or Go Home! is offline
Go Big or Go Home! is starting off with a positive reputation.
Battery is dying. Go get dealer to put in a new Motorcraft Max batt. Keep an eye on the proper cold cranking amps. When I bought my 14..Get in for first time and the truck did the same thing..They jumped it so I could test drive and the one knucklehead said it will be fine once you drive for a while it will recharge. I said if it were you buying the truck I would say its fine also..Before I bought truck they put a new batt in and its been fine and we have been down to -10 around here and many mornings in single digits..I bet the battery lost its uummf!!
Old 02-04-2014, 05:18 PM
kerm7807 kerm7807 is offline
kerm7807 is starting off with a positive reputation.
Definitely the battery. Mine was a year old and did the same exact thing until the 3rd morning it wouldn't start and wouldn't take a charge either. Happened to be a Saturday morning and I needed the truck. The dealership wasn't open so I went and bought a new battery from advance auto. I bought the gold with 3 year warranty that was 200CCA higher than the motorcraft. Wow!! My battery must have been dying for a while cause I didn't realize how fast it was supposed to turn over. That was last winter and I didn't even care if the battery was under warranty. I've had some other bad experiences over the years with motorcraft batteries. Good luck, but I'm pretty sure it's not the truck.
Old 02-04-2014, 05:21 PM
fg250's Avatar
fg250 fg250 is offline
fg250 is starting off with a positive reputation.
mine has been starting and we had one morning @ -21F....definitely sounds like your battery.
Old 02-04-2014, 06:56 PM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
Take it in and have the battery load tested. Mine is just past a year old and still starts fine. Coldest it's been here is -40F, and regularly got to -20F this winter. My truck sits outside all the time and does not get plugged in.
I'm guessing it's the battery, would be covered under warranty. Once mine is no longer covered, I'll buy an Optima dry cell battery for it. Those are about as good as it gets for a battery.
Programming PATS key with AutoEnginuity dchamberlain 1997 - 2003 F150 42 04-15-2015 03:33 PM
Glow Plug Testing Question RolnCl 1999 - 2003 7.3L Power Stroke Diesel 10 01-11-2015 08:17 PM
08 Ford Escape RKE programming error dukkman65 Escape & Escape Hybrid 0 12-11-2014 07:11 PM
2004 6.0 cutting out on highway p2290 lbo200688 6.0L Power Stroke Diesel 9 06-28-2014 11:20 PM
86 Bronco - Starter engages when put into reverse !! Ford_Eddie_Bauer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-16-2014 06:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
