Advice on front brakes '78 F-250 4x4
My haynes manual only describes how to do an F-150, and the blow up diagram I looked at online for an F-250 shows that Ive got to completely dismantle the locking hub assembly to change the brake pads?!?!?! This cant be right........ Is it?
Im no stranger to doing disc brake jobs, but Ive never done a brake job where I needed to completely take apart a hub to relace shoes and hardware.
IS THERE A SIMPLER WAY?
thanks.
thanks.
Agree... pad change is easy. Pull the lock bolt for the key, punch out the key and pull the calipers. If the wheel bearings haven't been serviced for a while... well its not a bad idea to pull the hub to clean/inspect/repack bearings. Still, not necessary for pad change.
MudDan
32
11-17-2012 01:14 PM
