Finally tore into my 460 MAF/SEFI project..
#62
on
#64
There should be one at the front of the engine by the oil filter mount and where the fuel pump would mount. Should also be one on top of the engine behind the intake manifold.
If you're worried about flow past it then do your engine a favor at the same time and run a line connecting the 2 oil sensor ports, increases flow to the back of the motor, and put the Oil Temp Sensor inline on the new feed line. Make sense?
#65
#66
on
#67
Do you already have a temp sensor or do you need to get one yet? If you don't have one and you really like the idea of putting it at the pressure sensor location, you could put a pipe Tee at the current pressure sensor location with the straight through vertical and the tee to one side. Place the pressure sensor in the side of the tee and get a long enough temperature sensor to run completely through the straight through portion of the tee and into the oil passage so that the tip of the sensor is immersed in the moving oil path.
