Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
2003 - 2007 Ford Pickup Truck Vacuum Pump Electric for Models with V8 6.0L Diesel
Old 06-28-2010, 03:29 PM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Check here for current pricing...2003 - 2007 Ford Pickup Truck Vacuum Pump Electric for Models with V8 6.0L Diesel Turbo
Our engine vacuum pumps motors are some of the highest quality replacements on the market!
This electric Air Vacuum Pump Motor for Ford diesel trucks is a new, aftermarket replacement motor. It is a direct replacement for the old electric vacuum pump motor. It produces extra vacuum that the diesel engines have trouble producing.
The original pump from Ford, after many years of use, tends to stop working. With the loss of this motor, all vacuum operated systems connected will stop working. This could include 4WD systems with vacuum operated hubs, heater, defroster, and A/C doors, emission devices, plus many more! If you are having problems with any of the above systems, it may mean that your electric vacuum pump is bad and this part could be eaxctly what you need.
This new electric vacuum pump motor has the following specifications:
Electrically powered with correct plug
Replaces dealer part numbers: 6C3Z2A451A, 6C3Z2A451BA, 4C3Z2A451BA, F81Z2A451BA, 6C3Z-2A451-A, 6C3Z-2A451-BA, 4C3Z-2A451-BA, F81Z-2A451-BA
Built to strict quality control standards
Limited lifetime warranty!
Fits the following diesel turbo engines:
V8-445ci 7.3L DIESEL Turbo Vin F
V8-363ci 6.0L DIESEL Turbo Vin P
If your check engine code is coming up with an electric vacuum pump problem, this could be due to a motor. Many pumps, due to the weather will corrode and freeze up on the inside, causing the pump assembly to malfunction. Replace your frozen or broken vacuum pump motor now with this great fitting, alternative.
This electric vacuum pump motor assembly makes a great replacement, and has good cost savings over a dealer vacuum pump assembly.
Backed by manufacturer's limited LIFETIME warranty.
For as long as the original purchaser owns the vehicle, in the event this pump should fail due to manufacturing defects, we will REPLACE the pump free of charge. Warranty is limited to replacement cost only (excludes shipping charges). Failure due to improper installation, or improper use is not covered. Please keep your invoice for proof of this warranty.
FREE SHIPPING
Old 01-30-2014, 02:59 PM
Wilfran's Avatar
Wilfran
Wilfran is offline
do you ship to South Africa
Old 01-31-2014, 07:32 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
Is that the one for were looking for? Sorry
We do ship internationally. The order has to be placed through the website, and you will be given an international shipping quote.
It should also include the duty fees (if I'm not mistaken). Thanks for asking.
Tony
Old 01-31-2014, 10:02 AM
Wilfran's Avatar
Wilfran
Wilfran is offline
Hi
Thanks for the reply. Every time I try to open your website it opens a new tab but the tab stays blank.
I am not sure what the issue is. I am looking for a vacuum pump for a 2005 ford ranger 2.5 Turbo diesel.
Would you have that if i can connect to your website.
thanks
Old 01-31-2014, 10:08 AM
1Aauto's Avatar
1Aauto
1Aauto is offline
Former Vendor
We currently do not carry one for that application. Thanks for asking, Tony
Bruker
04-28-2010 06:59 AM
Hervey Purcell
New Member Introductions
03-02-2008 04:03 PM
omni
22
09-21-2007 01:26 AM
wrenchturner
12-05-2003 08:32 AM
Quick Reply: 2003 - 2007 Ford Pickup Truck Vacuum Pump Electric for Models with V8 6.0L Diesel
