1992 Ranger Starter and Starter Solenoid - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-28-2003, 03:39 PM
Clarabelle Clarabelle is offline
Clarabelle is starting off with a positive reputation.
Question 1992 Ranger Starter and Starter Solenoid
Husband is out of country and now I have to fix the truck. Battery is pretty new, replaced solenoid next to battery this morning. Truck still won't start, just clicking away. Decided I needed to replace the starter, put the truck on jacks and went to the starter. At the starter solenoid there is a red cable attached, and a "loose" red wire, with a connector on the end. It would appear the connector just needs to be reconnected to the solenoid. But it won't "connect". Am I missing something? Should it not connect to the prong on the solenoid? Should I just replace the starter, and forget about the wire? Any help is appreciated. I do have Chiltons for our truck, but it doesn't show a picture of the prong on the starter solenoid.
Send help quick.
Thanks
Old 06-28-2003, 04:22 PM
OOPS, forgot: 81000 miles, manual transmission, 3.0
Old 06-28-2003, 05:42 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
Moved from 87-96 full size truck/van to Ranger forum, user does not have e-mail on.
Old 06-28-2003, 06:25 PM
Thanks Justin
Old 07-01-2003, 09:09 PM
CelticMace CelticMace is offline
CelticMace is starting off with a positive reputation.
Thumbs up 1992 Ranger Starter and Starter Solenoid
Yes, Clarabelle ...
The wire does clip on and should be easy to do so. I replaced my starter and then connected that wire with a special clamp that insured it does not come off the starter again. That little wire is a pain in the ahem! lol
I wont have to fix that again and my Ranger has probably a lot more miles on it than yours ... I have over 100,000 miles on it and the original starter was still working, until I had the problems I had and replaced it.
I wanted to my ranger!!!
CelticMace
Old 04-11-2014, 12:47 PM
Victoria Kelly Victoria Kelly is offline
Victoria Kelly is starting off with a positive reputation.
Question
I have a 92 2.3ltr ranger it wont stay running . I change the solenoid on the firewall it starts but wont stay running ... what did I do wrong?
Old 04-11-2014, 02:07 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Quote:
Send help quick.
Thanks
Could be wrong but IIRC Ford connected the small red power distribution wire to the starter relay not the starter solenoid.
The starter relay is the part that you replaced. The relay connects voltage to the solenoid.
What you are describing sounds like a weak battery or a bad connection.
Loosen the negative cable on the battery just enough so you can wiggle it back & forth a couple of times & retighten it. Does it start now?
If it still wont start do the same with the positive cable.
After doing the above with my 87 Ranger it still wouldn't start.
By simply jumping from the negative on the battery to the engine block I found that the negative battery cable was shot.
Old 04-11-2014, 03:37 PM
Quote:
If it runs until you release the key from the start position you probably have a bad ignition switch. When you turn the key one click do the idiot lights come on?
What you replaced was the starter RELAY, why did you replace it??
Old 12-13-2015, 07:17 PM
Ergobrood Ergobrood is offline
Ergobrood is starting off with a positive reputation.
1996 Starter issue. Bendix spinning but the truck isn't starting
Hello to everyone. I have a similar situation to the one that I read on this post.Yesterday After trying to start my 1996 2.3 Ranger I did struggle to turn it on, after a couple of times trying and after the sound that you are hearing on the video (https://youtu.be/md5zd-fvMPAit) started. Today in the morning while trying to do the same, it does not go any further and doesn't start. I had the clicking noise coming from the solenoid also but probably was because I drained the battery after trying several times. I have charged the battery and now the only noise that I get is the one that you see on the video. The battery marks 12.7 volts before doing any troubleshooting.
I think it might be the Bendix on the starter. But wanted to ask for your opinion. In case that you have had a similar experience with this.
I appreciate your help. Thank you very much.
Ford Ranger 2.3 Xlt 1996. 166000 miles
Old 12-14-2015, 03:05 AM
If it's a manual transmission pop start it, shove the clutch in at 50 MPH and turn the key off. Will it start now? If it does theres a busted tooth in the flywheel, If it still wont start yank the starter to see whats wrong with it.
Old 12-15-2015, 04:02 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Ergo, you might want to start a new thread.
Your youtube link is not working
and have you tried replacing the starter?
Old 12-16-2015, 03:06 PM
Well go figure this, the link does'nt work on my windows 8.1 PC, but it does work on my high buck state of the art $79.95 android tablet.
On the tablet i can hear the starter spinning, so the solenoid is shoving the starter gear in which completes the circuit to spin the starter.
Theres a missing tooth on the flywheel or the starter gear is busted.
Replaced glow plug relay, fried starter solenoid. Help? Codeman894 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 09-04-2016 07:17 PM
Solenoid, starter or ignition?? fyredude 1999 to 2016 Super Duty 15 07-15-2016 02:56 AM
Solenoid Wiring Help cynestor 1997-2006 Expedition & Navigator 13 06-14-2016 11:28 PM
Start circuit problems granny_rocket 1994.5 - 1997 7.3L Power Stroke Diesel 6 09-23-2015 05:39 PM
Do I need a new starter? bossgobbler 1999 - 2003 7.3L Power Stroke Diesel 12 04-30-2012 09:28 PM
Tags
1992, 2003, explorer, ford, picture, ranger, solenoid, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
