Trans Fluid
01-29-2014, 09:12 PM
on
Trans Fluid
Whats the BEST trans fluid to use in my 07 F150 4x4 ? the trans is a model 4r75e !
Thks
Cheers Bubba
01-30-2014, 12:50 AM
on
I always suggest using OEM fluids. However what does the truck do as far as work/demands
Maybe needs something that demands harsher conditions. It's not a hill climber is it
I've been a fan of Amsoil but always make sure you know what additives to use and not use
01-30-2014, 12:57 AM
on
Truck is a driver and trailer tower ! Thks Bubba
01-30-2014, 01:06 AM
on
As long as it's not some dollar store brand. OEM should do it. I'd check fluids before winter starts and top it off. Drain some to check for discoloration.
How's the shifting when the Trans hasn't warmed up?
01-30-2014, 06:48 AM
I believe the best fluid for that trans is Mobil 1 Synthetic ATF. It has the MERCON V rating that your trans requires.
01-30-2014, 08:28 PM
on
Quote:
Originally Posted by
Mark Kovalsky
Hmmm! Ford says i should use Mercon LV is this correct ?
Thks
Cheers
Bubba
02-02-2014, 08:41 PM
on
Is the Ford LV fluid a Semi or Full SYNTHECTIC fluid ? or ?
Cheers Bubba
02-02-2014, 10:03 PM
Are you sure that it takes LV fluid? I don't have your owner's guide, but I thought it took MERCON V fluid, not MERCON LV.
granny_rocket
05-10-2015 04:49 PM
Jc_4_07
07-07-2009 01:40 AM
883024x4
15
07-05-2006 12:34 PM
