2005 f150 rough idle and loss of power - Ford Truck Enthusiasts Forums
Old 01-29-2014, 10:03 PM
Spudy Spudy is offline
Spudy is starting off with a positive reputation.
Hello all
Joined the forum with hopes of getting my f150 running right so i can enjoy it like everyone else does. I have a 2005 Ford f150 with a 5.4 auto.
It has a rough idle(shakes the truck), very little power, and poor gas mileage. Randomly It will throw a code for misfire on 1 and/or 3 on start up only. It does seem to perform better within the first few of starting but dies right off after that. In fact i got stuck in the snow the other day and it could barely break the tires loose to try and get it out (almost put in 4low cause i didn't want to hurt the trans)
I have replaced:
Cats
Fuel pump
Plugs (motorcraft)
Random Coils
Did the timing chains and phasers
MAF
All new injectors
Intake gasket
Was at my mechanics and had a scanner on it and at idle the 1-4 cylinders are all show a negative cylinder contribution. But when you rev it up they all go to 0 across the board.
Was kind of thinking about the Variable Timing solenoid.
Any advice would be greatly appreciated.
Old 02-10-2014, 01:27 AM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
Sounds like your throttle body needs rebuilt
5.4 randomly misfiring C&W Auto and Diesel 2004 - 2008 F150 29 10-17-2016 09:30 PM
2000 F250 v10 rough/surging idle Madmooner Modular V10 (6.8l) 9 07-27-2016 10:46 PM
2007 Ford F-150 5.4 Random Rough Idle gradywray 2004 - 2008 F150 6 03-08-2016 07:04 PM
2005 F150 5.4 Randomly Dying DGMFORD 2004 - 2008 F150 3 07-24-2013 03:17 PM
Random Fail Safe LACityFD 2004 - 2008 F150 5 06-19-2009 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
