Tennessee Chapter Join Chapter Leader: harleymsn
Machine shops in the Tipton County area
Old 10-24-2014, 04:43 PM
hhight's Avatar
hhight
hhight is offline
Hello, fellow FTE TN Chapter folks
I've got a '78 F250 with a 400 that will need a rebuild in the not too distant future.
I was curious who you would recommend to do the machine work - turn the crank, shave the heads and block if needed, that stuff. I'm in Atoka, and prefer local, but if the place is the very best I could drive a ways.
Thanks, in advance, for your help?
Old 10-25-2014, 08:47 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
Sandy Walker - Walkers Machine Shop or something like that, on Jackson Avenue
Walker Engine
3554 Jackson Ave, Memphis, TN 38122
(901) 458-8692
The mans been in the business since way back when...
Old 10-25-2014, 09:20 PM
hhight's Avatar
hhight
hhight is offline
Thanks, GW
Old 11-03-2014, 05:36 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
How did that work out for you?
I bet one look around the shop was all you needed to see to know it was the real deal!
There's also a fella somewhere around the south Tipton county area I think name of David Gray, but he's retired, works at home, and I don't have a contact number for the guy.
Sandy is your best bet because it's a real business and he specializes in automotive and race car machine work.
~ He's an opinionated fella, from being around the Memphis racing scene as long as he has. I bet the first thing he tells you is that 400's and 351M's are DOGS as race engines.
But he has seen every kind of V8 engine build that you can do, and knows what works, what's fast, and what lasts a long time.
Old 11-04-2014, 07:50 AM
hhight's Avatar
hhight
hhight is offline
I've taken no action as of yet. Might not need to. I'm just figuring out what my options are at this point. I am grateful for the info. We here at FTE do know that a 400 has potential, though....
Old 11-05-2014, 12:04 AM
Greywolf's Avatar
Greywolf
Greywolf is offline
What you want to keep in mind is that there is no way in hell you can break that crankshaft under normal use.
That is what makes it special.
hhight
10-26-2014 06:33 PM
IowaTower
Iowa Chapter
01-29-2006 08:07 PM
78broncoman
Arizona Chapter
02-11-2004 11:02 PM
big_beast302
Michigan Chapter
05-22-2003 02:38 PM
CobraXP
Georgia Chapter
12-28-2002 01:04 AM
Quick Reply: Machine shops in the Tipton County area
