stupid Dodge forum. update
Hey guys. I went on to the dodge forum to find out about a voyager that I'm trying to fix for my niece. No one writes back. i guess I have gotten spoiled on FTE. Anyway I'm trying to change the front trans seal and I'm having a hard time getting the drivers side axle out. There's no place to pry and I'm not sure if it just comes out like the passengers side. I don't want to break something. Any one do one of these?
I got it. I'm surprised it came out.That notch could have been deeper. Like to take a grinder to it for the next guy. Thanks fordman67 for the reply. Hey, have you ever seen a front transaxle seal that doesn't leak when the motor is running or in any gear as long as you hold the brakes so the axle doesn't turn, but then when the axle starts turning fluid just pours out from behind the flywheel?
Is the tranny still bolted up? Dunno if this would shed any light, but it might be worth sliding the axle back in (might get away with not putting it in all the way, just enough to engage the splines, and then turn the axle, with the engine OFF, and see if that causes the bleeding. Same test with the engine running, turning the axle by hand, but tranny in Neutral or Park. Just to see under what conditions it bleeds out.
madpogue, That's a really good idea. but I feel I'm to far into it. I just hpoe that when I get it apart the problem is glaringly obvious. so i don't get it back together and still have the leak. Glad that someone agrees that this is strange. The story is the crankshaft position sensor was bad and when they removed it, it was broke off. So, after they replaced it, the van made a terrible noise. they removed the inspection plate and the broken piece was down in there. Sounds fishy to me. Now I really want to know what it is.
on
1 Post
The crank sensor goes into the bell housing . It reads off the tone ring on the flywheel . It needs to be removed before you drop the tranny , or you will break it . FYI , these things have a lot of issues with broken flywheels also . Unbolt it when the tranny is out and check for cracks . They break around the reinforcing ring , spin a few degrees , and " weld back together " .That could have started this hole thing .
No , if the flywheel is even SLIGHTLY cracked , replace it . I work on a fleet of dodge minivans . I see many come in for something as simple as a miss , or CEL , that is caused by a broken flywheel / flexplate . I also see worn thrust bearings in the motor that allow the crank to walk . That can cause your issue also ( I hope not ) Just things I want you to be aware of ! Check the crankshaft end play while you have it ! Best of luck !
These are the things I need to know. Funny thing I learn more about how to fix a dodge on the ford truck forum than on the dodge forum. Thanks. Is it just as easy to drop the motor and trans together to do this work? I had an escort that i did that once to change the motor. Lifted the front of the car with my engine hoist and rolled the thing out from underneath. That worked great.
