2wd to 4wd body swap whos done it? - Ford Truck Enthusiasts Forums
Old 01-29-2014, 12:49 PM
swampthang swampthang is offline
swampthang is starting off with a positive reputation.
Does the body from a f150 2wd directly swap over onto a f150 4wd frame? I understand the differences in the f250s over the years with the highboy frames but are all years 73-79 f150 the same 2wd and 4wd? What if anything has to be addressed. I'm seeing alot of nice 2wds pop up localy and it was gears turning in my head. Any help?
Old 01-29-2014, 01:12 PM
gpence's Avatar
gpence gpence is offline
gpence is starting off with a positive reputation.
Besides cutting the trans tunnel out & swaping to the 4x4 steering column is about all I can think of
Old 01-29-2014, 10:07 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
I sort of did. On paper it would appear that way, but I really just made a truck out of about 5 different ones.
I think for a regular cab, any 150 or 250 2wd would be an easy swap on to a 150 4wd frame.
Old 01-29-2014, 11:49 PM
brian1080's Avatar
brian1080 brian1080 is offline
brian1080 has a good reputation on FTE.brian1080 has a good reputation on FTE.
My Scab cab came from a 2wd auto (now 4x4 manual). All I had to do was cut out the floor and drill holes for the screws that hold the tunnel cover on. Everything else is the same.
Old 01-30-2014, 05:58 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
73-77 versus 78/79 you could possible have some wiring differences in the dash harness for different dash clusters, gauges versus idiot lights, I think....
But over all any 73-79 2wd body will go right on a 4wd chassis with what has been mentioned about the steering column/shifter. A 79 body 2wd to a 79 4wd chassis can be done in a weekend with a few friends.
Also a 73-74 or 5?? you can have a cab mounted gas tank/wiring and then 75 to 76 ish ?? a exposed gas cap in the bed, and a 77.5 to a 79 you will have one and possible have 2 gas filler necks with a gas flap. Something to consider, but not a deal breaker by no means.
No worries it have been done by alot of folks on here, so you will have tons of help.
Are you a Illinois FTE chapter member yet, you can always get to know your local Ford folks and request a FTE member helping hand with the swap.
http://www.ford-trucks.com/forums/forum122/
75 2wd F-150 body swap to 4wd Highboy frame RyanSbigblue 1973 - 1979 F-100 & Larger F-Series Trucks 11 02-04-2016 08:09 AM
Possible Project? I have some questions :P 1989f250xltlariat 1987 - 1996 F150 & Larger F-Series Trucks 5 12-22-2015 03:39 PM
2wd/4wd f350 frame differences ROBZ95XJ 1987 - 1996 F150 & Larger F-Series Trucks 1 04-22-2012 09:13 PM
will a 4wd lift kit fit a 2wd boatman41 1987 - 1996 F150 & Larger F-Series Trucks 4 04-14-2011 02:37 PM
1980 F150 2wd to 4wd conversion? Rogue_Wulff 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 02-22-2010 10:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
