Oklahoma Chapter Join Chapter, Leader:
Shot Peening in Tulsa Area??
Old 01-29-2014, 11:45 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Any of you have a recommendation for someone to shot peen a set of rods for me? Or, do you know how to do shot peening in a media blast cabinet?
Old 01-29-2014, 01:32 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Well, I may have answered my own question, but I'd still like your input. Anyway, I think I've found the place for having shot peening done. Talked to Fred at United Plating Work and took these notes:
  • $75 for a set of 8 rods if they have to mask the bores, and $50 if not
  • They are an aerospace company and do it quite scientifically. They measure the thickness of the part and refer to a MIL Spec that gives them the guidelines as well as the required test strips. They load up with the appropriate shot, set the PSI, and shoot against a test strip that must arc to a certain height. Then they shoot the part, and then shoot a test strip when done to prove they are still in calibration.
  • A media blast cabinet like mine won't have enough vacuum to pull the steel shot properly. They use an elevator system that raises the shot above the work and then introduce the air as the shot falls.
  • Proper shot peening increases the fatigue life 10x. For instance, if you took a part that would work-harden and fail after 10 bends and shot peened it the failure point would be somewhere beyond 100 bends.
Old 03-12-2014, 02:10 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Just as a follow up, here's what I posted in Dad's Engine thread on the 80 - 86 forum:
Picked up the rods after having them shot-peened. Here's a before pic:
And here's an after:
Then a close-up of the numbers, for reference, showing the surface texture:
Old 03-12-2014, 03:51 PM
smoothcriminal69's Avatar
smoothcriminal69
smoothcriminal69 is offline
Sorry to be a noob here but what was your reasoning for this? I'm no metallurgist, but wont that change the actual hardness of the rods, I know it essentially gives them a tough skin for crack prevention, but isn't there a bit of elasticity needed?
Old 03-12-2014, 03:58 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Here's a blurb from http://en.wikipedia.org/wiki/Shot_peening on shot peening:
Depending on the part geometry, part material, shot material, shot quality, shot intensity, shot coverage, shot peening can increase fatigue life up to 1000%.
Fred said that if you were able to shot peen a piece of wire that would normally work-harden and break when you bent it 10 times, that it would go over 100 times after shot peening. And he basically said I won't be able to break those rods, that other parts of the engine are now the failure point, not the rods.
Old 03-12-2014, 04:05 PM
smoothcriminal69
Read the article and I'm sold, looks like that will be the standard in my rotating assemblies going forward. Thanks for the great info!
Old 03-12-2014, 04:08 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
No problem. By the way, will you be home in the September time frame? I plan to have another get-together at my place for the only FTE chapter that is OK and would love to have you come and meet the folks.
Old 03-12-2014, 04:18 PM
smoothcriminal69
I wish, I haven't been home since 2011 this is my 1 trip home for this tour here. It's just too darn expensive to fly the whole family home(3.5k), but in the next few years ill be looking for an Engineering job in the area, and hopefully finally settle down.
Old 03-12-2014, 04:19 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Hope that works out for you. We lived in the UK for a while and travel home was certainly expensive, so I understand.
JWA
Garage & Workshop
01-09-2014 08:08 AM
theWeezL
Projects
40
04-19-2011 01:07 PM
ampslw
04-10-2010 07:28 PM
Secret Agent 069
02-24-2008 01:30 PM
Secret Agent 069
British Columbia
02-24-2008 11:31 AM
Quick Reply: Shot Peening in Tulsa Area??
