I believe he's referring to the rocker box and the 8 bolts that hold down the rocker arms. The ones that are torqued with the head bolts are the same size and same torque value.
[QUOTEpccpartsman;14008735]I believe he's referring to the rocker box and the 8 bolts that hold down the rocker arms. The ones that are torqued with the head bolts are the same size and same torque value.[/QUOTE]
Yes, I've always called it a riser but rocker box is probably more correct. I'm referring to the bolts that hold it to the head, not the ones that hold the rocker arms beside the head bolts.
