Can someone help me with my 1950 F1 VIN identification? - Ford Truck Enthusiasts Forums
Old 01-28-2014, 05:39 PM
Thbifeb Thbifeb is offline
Thbifeb is starting off with a positive reputation.
I have been searching for how to identify my 1950 Ford F1 and I can't seem to find the thread. I thought I read where you could identify the original color.
My VIN is 97HC 321410 CH
If anyone can help me identify any part of my VIN I would greatly appreciate it.
Thanks
Thbifeb
Old 01-28-2014, 05:47 PM
mwarner1948's Avatar
mwarner1948 mwarner1948 is offline
mwarner1948 is starting off with a positive reputation.
97HC 321410 CH
9=49-50
7H=226 ci 6cyl
c=1/2 ton
321410=production series
CH (no idea)
Old 01-28-2014, 05:50 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Hey Thbifeb
The firewall stamping / stencil is the only guide for the older years for color or assembly plant. The VIN breakout is as mwarner shows.
DW
Old 01-28-2014, 06:20 PM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Quote:
Originally Posted by FortyNiner View Post
Hey Thbifeb
DW
I've discovered that a lot (but definitely not all) of the VIN numbers will have the assembly plant stamped at the end on the firewall tag. For instance, a lot of the Louisville trucks have LOU stamped after the VIN. In this case, the "CH" could very well mean the Chicago factory? That VIN number sequence is well within the 1950 range.
EDIT: Here's the legendary multi-year thread that will teach you more than you ever want to know about deciphering those VIN's and firewall stampings. http://www.ford-trucks.com/forums/42...n-cut-off.html
Old 01-28-2014, 10:36 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
CH is Chicago.
Old 01-29-2014, 09:31 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 51PanelMan View Post
CH is Chicago thru 1952.
G = Chicago: 1953 thru today.
help identifying the numbers Dan Rose 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 11-03-2014 04:06 PM
For sale: 1950 F1 gas tank - 1 brand new tank and 1 old tank Thbifeb Ford Truck Parts for Sale 0 08-24-2014 04:23 PM
Wanted: 1950 F1 output shaft Thbifeb Ford Truck Parts for Sale 0 05-03-2014 06:31 PM
Carb rebuild questions for my 1950 F1 Thbifeb 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-15-2013 08:12 AM
1950 Ford F1 passenger door lock removal? Advice? Thbifeb 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-31-2013 03:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
